i just started to play around with Openhab. First i tested on my Windows PC and a RFXtrx433 and a ZME_UZB1 Z-Wave USB-Stick. Both worked great.
Now i want switch to a “productive” environment, which is a Solidrun CuBox i4Pro. As distro i used this one:
http://www.igorpecovnik.com/2014/08/19/cubox-i-hummingboard-debian-sd-image/
I copied all files from my local Openhab folder to the Linux box, plugged the two devices in the box, changed the ports and started. Everything seemes to work. But the two devices. The bindings aren’t loaded or they don’t connect correctly to the devices, i don’t know. I just don’t get any data…
I think they are mounted correctly:
root@cubox-i:~# lsusb
Bus 001 Device 006: ID 0658:0200 Sigma Designs, Inc.
Bus 002 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
dmesg:
[ 3.593973] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 3.578885] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB
root@cubox-i:~# ls -alg /dev/ttyUSB0
crw-rw—T 1 dialout 188, 0 Aug 21 10:45 /dev/ttyUSB0
root@cubox-i:~# ls -alg /dev/ttyACM0
crw-rw—T 1 dialout 166, 0 Aug 21 10:45 /dev/ttyACM0
Anything i can try?
