a small rule example - maybe useful to someone on how to get a human readable location string from a location item:
Item
String PatrikLocationString "Patrik [%s]" <place>
Rule
val String GoogleAPIKey = "<your google API key>" // not sure if mandatory
rule LocationStringPatrik
Item PatrikLocation changed
val PointType locationPatrik = (PatrikLocation.state) as PointType
val patrikLatitude = locationPatrik.latitude
val patrikLongitude = locationPatrik.longitude
val geocodeURL = "https://maps.googleapis.com/maps/api/geocode/json?latlng=" + patrikLatitude + "," + patrikLongitude + "&sensor=true&key=" + GoogleAPIKey
val String gecodeResponse = sendHttpGetRequest(geocodeURL)
val String formattedAddress = transform("JSONPATH", "$.results[0].formatted_address", gecodeResponse)
PatrikLocationString.postUpdate(formattedAddress)
Hi, i am trying to get this figured out. I have my location (item= DeviceID1_coords; it is lat,long together) plotted on a Map taken from your great GoogleMap V3 API html. So now i would like to show address on there. I assume that is what this can do? My rule looks like this
val String GoogleAPIKey = "Number HERE" // not sure if mandatory
rule GeoMap_address
Item DeviceID1_coords changed
val PointType location_DeviceID1 = (DeviceID1_coords.state) as PointType
//val patrikLatitude = locationPatrik.latitude
//val patrikLongitude = locationPatrik.longitude
val geocodeURL = "https://maps.googleapis.com/maps/api/geocode/json?latlng=" DeviceID1_coords "&sensor=true&key=" + GoogleAPIKey
DeviceID1_coordsString.postUpdate(formattedAddress)
i // out long and lat b/c they should already be combined in the first val (?). I can run the geocode URL manually putting in the item value (ie, long / lat) and it gives the proper page of outputs it seems. But wondering what I need to do to put it on top of my location map – and it does not seem to work unless i add the coordinates manually at the end of the URL in browser. I am certain to have messed some things up.
Thank you Patrik,
I made the change, but do not see any address applied to the map. Let me know what else i could provide (i may not be able to reply for several days).
I have in the past but not this time. Just put it through that, and says the value of location_DeviceID1 is not used. Also “DeviceID1_coordsString” is underfined.
When I get back, I will put printIn into the rule.
rule "LocationPatrikChanged"
Item ItemPatrikLocation changed
val _apiKey = ItemGoogleMapAPIKey.state
val _position = ItemPatrikLocation.state as PointType
val _url = "https://maps.googleapis.com/maps/api/geocode/json?latlng="
+ _position.latitude + ","
+ _position.longitude
+ "&sensor=true&key=" + _apiKey
val _geocodeJSON = sendHttpGetRequest(_url)
val _address = transform("JSONPATH", "$.results[0].formatted_address", _geocodeJSON)
PatrikLocationString.postUpdate(_address)
Patrik, I am almost there. My rule is below - note: since DeviceID1_coords has lat,long combined, i only use “_position” in url.
This now does get me to a url with a whole bunch of unformatted data - and i can see the address in some parts (ie, under formatted address of the url page).
rule "GeoMap_address"
val _apiKey = "<myAPIkey>"
val _position = DeviceID1_coords.state as PointType
+ _position
DeviceID1_LocationString.postUpdate(_address)
The problem is, I am not getting a clean address in my ‘DeviceID1_LocationString’ – it is pulling in all the information from that url, in the unformatted form. I put 'String DeviceID1_LocationString “DeviceID1 [%s]” in my items.
[In the end, I would just want to pull the address and the town. ]
val _url = "http://maps.googleapis.com/maps/api/geocode/json?latlng=" + DeviceID1_coords.state.toString + "&language=english&sensor=false"
[Edit:] I guess you’ll probably want to add your API key back in. I just didn’t have one for testing.
can you post the log and possible related error(s)?
I’ll extend the 1st post with an example on how to display the info on the sitemap … but if you have it stored in an item you basically just add it to a/the sitemap.
That’s what I’ve done, just adding to the sitemap whereas the Group get’s named, not a text item
Group item=giPhone
Mapview item=iPhone_Coordinates_M height=5
Mapview item=iPhone_Coordinates_A height=5
So the item gets updated. the item is of type string:
String Location_String "Ort " <place_2> (giPhone)
Logfile: (can’t see any error in there)
2017-08-02 16:45:01.257 [ItemStateChangedEvent ] - iPhone_Location_Timestamp_A changed from 2017-08-02T16:35:23.942+0200 to 2017-08-02T16:40:09.594+0200
2017-08-02 16:45:01.285 [ItemStateChangedEvent ] - iPhone_Coordinates_A changed from 48.1234…,8.12345… to 48.3456…4,8.3456…
2017-08-02 16:45:01.601 [ItemStateChangedEvent ] - Location_String changed from Street 123, 12345 City, Germany to Street 456, 45678 City, Germany
