I want to control the shutters (HM-LC) with a HMIP-WRC2.
I tried to create a rule: create rule → Add Trigger → Thing Event → choose HMIP-WRC2. Now I want to select the channel to be triggered, but if I click on “Channel”, nothing happens.
Am I doing this the right way or am I doing this totally wrong?
- Platform information:
- Hardware: RaspberryPi4
- OS: openhabian
- Java Runtime Environment: ?
- openHAB version: 4.0.0.M4
HMIP-WRC2 switch:
UID: homematic:HMIP-WRC2:3014F711A000041F299ED032:00019F2997405C
label: Taster WZ Rolladen
thingTypeUID: homematic:HMIP-WRC2
configuration:
HMP_0_CYCLIC_INFO_MSG_DIS_UNCHANGED: 0
HMP_2_DBL_PRESS_TIME: 0
HMP_0_CYCLIC_INFO_MSG_DIS: 20
HMP_2_LONG_PRESS_TIME: 0.4
HMP_0_ENABLE_ROUTING: true
HMP_0_LOCAL_RESET_DISABLED: false
HMP_0_ARR_TIMEOUT: 10
HMP_0_LOW_BAT_LIMIT: 2.2
HMP_0_DUTYCYCLE_LIMIT: 180
HMP_1_REPEATED_LONG_PRESS_TIMEOUT_UNIT: M
HMP_1_REPEATED_LONG_PRESS_TIMEOUT_VALUE: 2
HMP_2_REPEATED_LONG_PRESS_TIMEOUT_UNIT: M
HMP_0_CYCLIC_INFO_MSG: 0
HMP_1_LONG_PRESS_TIME: 0.4
HMP_1_DBL_PRESS_TIME: 0
HMP_2_REPEATED_LONG_PRESS_TIMEOUT_VALUE: 2
HMP_0_CYCLIC_INFO_MSG_OVERDUE_THRESHOLD: 2
bridgeUID: homematic:bridge:3014F711A000041F299ED032
