Reading API values how? What binding? How often are the values updated? What are these values? What is the type(s) of the Items? Use them how? What happens tomorrow?
All you’ve done is restate the problem as an XY Problem. An XY Problem is one where you’ve already decided how to solve a problem where another approach might (and usually is) a better solution.
Yes it happens tommorow. Values was strings i converted them to number.
Part of rule
Time cron "0 1 0 * * *"
var result1 = sendHttpGetRequest('https://www.nordpoolgroup.com/api/marketdata/page/59?currency=EUR&endDate=')
var String cena1 = transform ("JSONPATH", "$.data.Rows[0].Columns[0].Value", result1)
cena01Str.sendCommand(cena1)
var Number formatedNumber = Math::round(((cena01Str.state as Number) / 1000 * 100.00).floatValue()) / 100.00
//logInfo("Cena nākamai dienai pa stundām, String to Number convert", "Formated price is: " + formatedNumber)
cena01Num.sendCommand(formatedNumber)
This isn’t going to work like you think it is. Commands are processed asynchronously. If you send a command to an Item, it is highly unlikely that the Item will have changed state by the next line of code in the rule. It will most of the time still be in the old state.
And on top of that, I’m guessing cena01Str is a String Item. You can’t just cast the state of a String Item to a Number. It’s going top be a String.
And it all seems a bit redundant and pointless. You are pulling a JSON string, extracting a property of it as a String, commanding an Item with the String, then trying (unsuccessfully) to convert that String to a Number, do some math with it and then commanding a different Item.
Why can’t you just command cena01Num in the first place and avoid all this work that frankly isn’t accomplishing anything productive?
val cena1Str= transform("JSONPATH", ...
val cena1Num = Float::parseFloat(cent1Str)
var formatedNumber = Math::round(cena1Num / 1000 * 100.00) / 100.00 // you don't need floatValue, everything is already a float, and this calculation makes absolutely no sense
Why sendCommand here? Does something immediately happen when the command is received? If all you are doing is changing the state of the Item you should use postUpdate.
And none of this shows what you mean by “use item1 at 13:00,…”
Thank you for help i changed a code in section cena01Str postUpdate and now everything work fine.
I am asking is there possible to read several item values and overwrite them in one item.
Now i am getting item1 is on 13:00(with some value) after that item2 is on 14:00 (with some value) i want to transfer this values to a single item. Like item1 to itemNow than item2 to same item.
Is there possible to use some pattern or i need to make 24 rules?
This is working fine, no error in log and no missed values. Don’t know if its good quality code, but for me as sunday code write it is enough.
rule "Cena nākamai dienai pa stundām, String to Number convert 0 1,3 * * * * 1 0 * * * ?"
Time cron "0 1,3 * * * * "
cena01Str.postUpdate(cena1)
var String cena2 = transform ("JSONPATH", "$.data.Rows[1].Columns[0].Value", result1)
cena02Str.postUpdate(cena2)
var Number formatedNumber2 = Math::round(((cena02Str.state as Number) / 1000 * 100.00).floatValue()) / 100.00
cena02Num.sendCommand(formatedNumber2)
You can do it all in one rule. Trigger the rule once per hour on the hour with a cron expression and test to see what time it is from now to determine what to send to the Item.
You could also put this into the HTTP binding with a once per hour polling period and use a Script transformation to update the Item based on the time of day. In Rules DSL the transform would look something like this:
val currHour = now.getHour()
transform("JSONPATH", "$.data.Rows[currHour].Colulmns[0].Value", input)
In JS Scripting the transform would be a little cleaner since JS supports JSON natively:
What you are doing with these values and the nature of the actual JSON is and this still smells like na XY Problem, so I had to make assumptions.
Then you don’t even need a rule and you just have the one Channel and one Item.
I’m assuming that at midnight you’d read row 0, at 1 am you’d read row 1, and so on.
You’ve provided no details so That looks like the pattern of this data. But everything is labeled so generically and there are no details provided (e.g. an example JSON and not just generalities about what you are using it for) I either have to make massive assumptions and hope you figure it out, or provide similarly vague and generic advice and hope you figure it out.
Your two examples read Rows[0] and Rows[1] but only reads Columns[0] so
This is what you get when you don’t provide any details.
