I am trying to setup openHAB Cloud Connector but it keeps telling me I’m offline
I checked the log and it says
2019-03-30 23:09:00.082 [WARN ] [o.openhabcloud.internal.CloudService] - You are running Java 1.8.0_65 - the openhab Cloud connection requires at least Java 1.8.0_101, if your cloud server uses Let’s Encrypt certificates!
2019-03-30 23:12:02.259 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
I tried searching how to update to java 1.8.0 101 but can’t find the commands for raspberry pi.
Also it gives an error when I try to send a notification using this
var NotificationAction = org.openhab.io.openhabcloud.NotificationAction;
NotificationAction.sendBroadcastNotification(“This is a broadcast test”);
The error is
java.lang.RuntimeException: java.lang.ClassNotFoundException: org.openhab.io.openhabcloud.NotificationAction.sendBroadcastNotification
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:397) ~[?:?]
Caused by: java.lang.ClassNotFoundException: org.openhab.io.openhabcloud.NotificationAction.sendBroadcastNotification
at jdk.nashorn.internal.runtime.NativeJavaPackage.classNotFound(NativeJavaPackage.java:162) ~[?:?]
at jdk.nashorn.internal.scripts.Script$15$^eval_.:program(:2) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:640) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:228) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:393) ~[?:?]
I don’t know if the Java version is causing the notification not to be sent, if not how would I fix that?
