Hi all,
is there a way to use a thing channel as a label and another channel as a thing state?
Cheers,
K.
Hi all,
Cheers,
K.
Can you provide more details on what you are asking? What binding and maybe a sample output?
That is your item.
Can you give an example of what you are tring to do?
If multi channel linking is what your looking for then see:
Labels are also defined in sitemaps.
We are all assuming a 2.x version of OH.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
Thanks for the quick response to both of you. I’ve read the topic about multi-channel but examples are not very informative (at least for me).
Binding is 2.x.
A binding that I have created(ParadoxAlarmBinding) retrieves information from a security system. In this system you have defined “zones” and “partitions”. Each entity provides several channels, for example:
Is that possible with multi channel binding?
Let’s assume I have a thing called zoneThing1, a label channel paradox:bridge:zoneThing1:label and channel paradox:bridge:zoneThing1:state.
What would be the example item definitioin which does the magic? ![]()
Thanks,
Konstantin
If you can get your target text into an Item in the usual way, you can do this with rules.
A rule would listen for the target text Item state changing, then use it set the label of your other Item
otherItem.label = "some text"
Don’t forget you may need to add formatting too e.g "text [%s]"
Do not expect any of the UIs to be very responsive to label changes - it’s not a properly supported dynamic action.
But for something like reading and setting a description at startup, it should work reasonably well.
I just added the Development tag for you. Perhaps some of the developers have ideas too.
