Hi!
I would like to use the Harmony’s starting trigger inside a rule. Is there a function which can return the current trigger (like Things have getThingStatusInfo)?
Thanks!
Hi!
Thanks!
Yes, there are several examples for this in the docs:
rule "Starting TV"
Channel "harmonyhub:hub:GreatRoom:activityStarting" triggered Watch_TV
logInfo("Harmony", "TV is starting...")
rule "TV started"
Channel "harmonyhub:hub:GreatRoom:activityStarted" triggered Watch_TV
logInfo("Harmony", "TV is started")
rule "Going off"
Channel "harmonyhub:hub:GreatRoom:activityStarting" triggered PowerOff
logInfo("Harmony", "Hub is going off...")
rule "Hub off"
Channel "harmonyhub:hub:GreatRoom:activityStarted" triggered PowerOff
logInfo("Harmony", "Hub is off - no activity")
I think this answers what you are looking for:
These are what I’m Looking for. I was unable to find it. Thanks!!
For JSR libs, these are even easier:
@rule("Test rule")
@when("Channel harmonyhub:hub:LivingRoomHarmonyHub:activityStarting triggered")
def test_rule(event):
test_rule.log.info(str(event.event))
You can easily use event.event
for this.
If you have multiple triggers with not just Channel triggers in it, you can do something like this, so your rule won’t fail:
@rule("Test rule")
@when("Item Test_Switch received command")
if hasattr(event, 'event'):
else:
# Do anything here when not a channel triggered this rule
test_rule.log.info("No attrib")
You can even get the triggering channel with event.channel
. These were the ones I was looking for then, now it is much easier to use
More details on what you might find in event
Rather than using str
, you can use event.event.toString()
