So i can have different sitemaps and configurations on HABpanel to start on different tablets, i can make other sitemaps not to show on the tablet but i can’t restrict users from accessing other sitemaps.
HABpanel doesn’t use sitemaps - it’s independent of them. If you only use HABpanel, you don’t need sitemaps at all.
But you can have a different configuration for each HABpanel. Make a master one which has all your stuff on it and when you want a new panel configuration, save the master configuration to a new panel configuration and give it a new name when you save it.
If you want to restrict access to a particular user, you could have a keypad widget on the first page of each panel which, with a set of rules, would stop all panel functionality until a correct code was entered. Each user could have their own code.
There’s probably a better way of doing it and I’m sure someone will be along in a minute to suggest that.
I’m thinking of having some more functionality on my panels controllable only with a keypad after the child of one of my friends decided to go to every screen and randomly press buttons and turn things on and off.
yes ist correct. A restriction is with onboard Tools of OH not possible.
My Workaround is to use the “kiosk mode”. Which starts the browser in full Screen, with no address bar (linux).
