I have set a username like this user=pwd in the user.cfg, and security:option=EXTERNAL in openhab.cfg However i can login into https://my.openhab.org/ and see all my events and items. What am I missing to get it to work on my android phone/browser?
I thought I should use my my.openhab username(xxxxx@gmail.com) , but its still just times out with errror code 504. When should you add users to the users.cfg file?
Thanks, I have UIUID and secret working correctly otherwise i would not have been able to log into my.openhab, users.cfg is left completly empty(the file is still there though…)
My cfg file looks like this:
# the Netmask to define a range of internal IP-Addresses which doesn't require
# authorization (optional, defaults to '192.168.1.0/24')
security:netmask=192.168.1.0/24
the rpi is running on 192.168.1.156 static IP, do I need to open up some ports in my router?
[quote=“skatun, post:7, topic:3859, full:true”]
the rpi is running on 192.168.1.156 static IP, do I need to open up some ports in my router?[/quote]
No, definitely not. That is one of the big advantages of my.openhab, you don’t need open ports on your router.
Sorry, I have no idea what is wrong with your setup or network config …
Thanks, I have UIUID and secret working correctly otherwise i would not have been able to log into my.openhab, [/quote]
I don’t think so: I’m pretty sure that UUID and secret are only used when you access your local instance through my.openhab.
In case you log into http://my.openhab.org only your username and password are used, not your UUID and secret.
So you should double check if your UUID and secret are correct.
Yeah thought so,
Thats why I am tumbling in the dark here, and why I can’t figure out where the problem is. Maybe I will try creating a new my.openhab profile, just to test out that possibility as well.
[quote=“skatun, post:10, topic:3859, full:true”]
Maybe I will try creating a new my.openhab profile, just to test out that possibility as well.[/quote]
No, you don’t have to. Just delete UUID and secret and restart openhab, they will be created automatically. Then login to my.openhab and put UUID and secret into your profile, that’s it.
[quote=“skatun, post:12, topic:3859, full:true”]
The UIUd and secret does correspond to the files on the rpi, However i can try to reboot and recreate them if you think thats the issue.[/quote]
A quick update on the myopenhab issue, I got a second rpi the other week, created a second account. On this one it works smooth, same files so I guess the issue is in some rpi settings not allowing remote access somehow.
So what i will do is to make a copy of the image on the second rpi when i get the time to do it…
But when I want to open existing sitemap =demo then it works, works without end until timeout. Sometimes before timeout throws out partially produced HTML of the webpage.
Any idea?
Update:
I started to tail logs/[DATE].request.log and HTTP request is there:
GET /openhab.app?sitemap=demo
GET /WebApp/Design/Render.css
GET /jquery.miniColors.js?
GET /WebApp/Action/Logic.js?
GET /jquery,min.js
here it blocs and browser is working without result
same Android application: some requests coming to logfile but response HTTP ERROR: OK
