Cypris2010
(Fabian Bott)
January 30, 2018, 11:23am
1
I’m trying to configure a color item, witch uses mqtt to send the color to my esp8622 with the tasmota firware running. On the ESP is a ws2866 led / neopixel.
In my understanding the mqtt channel for this is “cmnd/sonoff/color” and the argument has to be passed as a hex value.
I can’t get my head arund thing an I can’t find anything here in the forum ore elsewhere. (Or I’m looking the wrong way).
Has anybody an idea?
binderth
(Thomas Binder)
January 30, 2018, 11:47am
2
I don’t quite get your issue and the problem you’re facing
Please read the docs:
Please come back with a specific question, if there’s still problems after that.
imhofa
(Andreas Imhof)
January 30, 2018, 2:40pm
3
Maybe you are looking for something like this:
or this:
Joe_Lawrence:
Hopefully some of you color Gurus can help me with a color problem I am having with this device -> EZMultiPli . In the manual it is first stated, "LED Color EZMultiPli has a color LED beneath the motion sensor dome. This LED is a convenient night light or an indicator light. The LED can be set to any of eight colors via the Z-Wave Color Switch Command Class : 1)BLACK (off) 2)WHITE 3)RED 4)GREEN 5)BLUE 6)AQUA 7)PINK 8)YELLOW A Z-Wave BASIC SET ON/OFF also controls the LED but it only uses the …
or this:
PHAN:
Hello rlkoshalk, first of all thank you so much for your answer. Yes, I have read all the Beginner's tutorial as well as the standard documentation provided in the openhab website and GitHub repositories(and of course lots of google searches). What I don't fully understand is how the color item "outputs" the command. For example a switch outputs ON or OFF, a dimmer outputs an integer between 0 and 100, etc. But when you say Color outputs HSB, in what format? I mean, it can be 255,122,009 or 25…
