Has anyone ported the uiSemantics scripts to the new Graal ECMAStricpt 2012 yet? I think some calls look a bit different. Or there are fundamental improvements in the meantime. Can someone maybe post their current implementation?
The Tutorials and Solutions category is a place to post a tutorial or solution, not a place to request one.
Translating those scripts to JS Scripting should be relatively easy. Everything you need is documented in the JS Scripting docs. I will be much shorter.
