I’ve been debugging a rule off and on for a long time. What happens is when my flakey RasPi in the garage goes offline I’m sent a notification. I put a flag into a global Map<GroupItem, Boolean> so when the machine comes back I want to send another notification saying as such if this flag is set.
If I use a SwitchItem as the key this works like a charm. When I use a GroupItem as the key it doesn’t work. I get “null” when I try to pull the flag out of the map even when I know for certain that GroupItem is a key in that map.
If I use the name of the group and a Map<String, Boolean> it works like a charm (my current workaround).
Could this point to .equals not working on GroupItem? It looks like it uses the GenericItem’s implementation of equals which does a check on the state as the last check. If a new GroupItem is created every time the rule is executed then in my use case below equals will always return false because the group’s state is now different than it was when I added the flag to the key.
If my analysis is correct, should I post a bug report or just leave using the name as an acceptable work around until OH2 comes out and we see if it is fixed then and if not then file the report? I’d hate to make busy work on code that is about to become deprecated. Clearly it isn’t a problem others have encountered.
Here is a simplified version of the code. NOTE: I also have a Map<GroupItem, Timer> below, but the code works even if that Map doesn’t work, which is why I haven’t see this behavior until now.
Below fails as written but if I use gr.name as the key it works as expected.
val Map<GroupItem, Timer> timers = newHashMap
val Map<GroupItem, Boolean> notified = newHashMap
val Functions$Function3 procChange = [ GroupItem gr, Map<GroupItem, Timer> timers, Map<GroupItem, Boolean> notified |
if(gr.state == OFF) {
if(timers.get(gr) == null || timers.get(gr).hasTerminated) {
timers.put(gr, createTimer(now.plusMinutes(1), [|
Notification_Proxy.postUpdate("The " + gr.name + " controller is still offline after one minute")
notified.put(gr, true)
timers.put(gr, null)
else { // Now ON
if(timers.get(gr) != null) {
timers.get(gr).cancel
if(notified.get(gr)) {
Notification_Proxy.postUpdate(gr.name + " is back online")
notified.put(gr, false)
