Alongside Openhab2 I am using Homey in my setup.
Because the emulator can also trick Amazon echo etc. I was hoping I could do the same with Homey.
There is a Homey App (=Binding) to talk to a Hue Bridge.
Unfortunately it is not finding my OpenHab Hue Emulation.
I have installed the Binding, Configured items, and they also show op in /api/index.html
{"lights":{"PortiekS1_Switch":{"state":{"on":false,"bri":-1,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"Portiek","modelid":"LWB004","uniqueid":"PortiekS1_Switch","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}},"ZithoekS1_Switch":{"state":{"on":false,"bri":-1,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"Zithoek Switch","modelid":"LWB004","uniqueid":"ZithoekS1_Switch","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}}}}
So this part of the setup seems to work.
I have enabled pairing mode, and also explicity configured the discovery ip.
I have enabled logging to debug level.
08:47:46.992 [DEBUG] [ulation.internal.HueEmulationServlet] - 192.168.1.189: GET /api/discovery.xml
08:47:59.215 [DEBUG] [ulation.internal.HueEmulationServlet] - Device pairing enabled : false
08:47:59.235 [DEBUG] [org.openhab.io.hueemulation ] - ServiceEvent MODIFIED - {javax.servlet.http.HttpServlet}={service.pid=org.openhab.hueemulation, service.config.category=io, service.config.label=Hue Emulation, discoveryIp=192.168.1.198, component.name=org.openhab.hueemulation, component.id=199, pairingEnabled=false, service.config.description.uri=io:hueemulation, service.id=325, service.bundleid=212, service.scope=bundle} - org.openhab.io.hueemulation
08:48:05.729 [DEBUG] [ulation.internal.HueEmulationServlet] - Device pairing enabled : true
08:48:05.750 [DEBUG] [org.openhab.io.hueemulation ] - ServiceEvent MODIFIED - {javax.servlet.http.HttpServlet}={service.pid=org.openhab.hueemulation, service.config.category=io, service.config.label=Hue Emulation, discoveryIp=192.168.1.198, component.name=org.openhab.hueemulation, component.id=199, pairingEnabled=true, service.config.description.uri=io:hueemulation, service.id=325, service.bundleid=212, service.scope=bundle} - org.openhab.io.hueemulation
08:48:09.941 [DEBUG] [ulation.internal.HueEmulationServlet] - 192.168.1.189: GET /api/discovery.xml
08:48:38.656 [DEBUG] [ulation.internal.HueEmulationServlet] - 192.168.1.189: GET /api/index.html
08:56:47.241 [DEBUG] [ulation.internal.HueEmulationServlet] - Device pairing enabled : true
08:56:47.264 [DEBUG] [org.openhab.io.hueemulation ] - ServiceEvent MODIFIED - {javax.servlet.http.HttpServlet}={service.pid=org.openhab.hueemulation, service.config.category=io, service.config.label=Hue Emulation, discoveryIp=192.168.1.198, component.name=org.openhab.hueemulation, component.id=199, pairingEnabled=true, service.config.description.uri=io:hueemulation, service.id=325, service.bundleid=212, service.scope=bundle} - org.openhab.io.hueemulation
Other than my manual requests to /api/discovery.xml and /api/index.html I see nothing happeningen. Maybe the UPNP isn’t happening correctly? How can I check that. Also, I am seeing empty things in my discovery.xml. Should that be the case?
<?xml version="1.0" encoding="UTF-8" ?>
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<URLBase>http://192.168.1.198:8080/</URLBase>
<device>
<deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
<friendlyName>openHAB Hue Emulation</friendlyName>
<manufacturer>Royal Philips Electronics</manufacturer>
<manufacturerURL>http://www.philips.com</manufacturerURL>
<modelDescription>Philips hue Personal Wireless Lighting</modelDescription>
<modelName>Philips hue bridge 2015</modelName>
<modelNumber>929000226503</modelNumber>
<modelURL>http://www.meethue.com</modelURL>
<serialNumber>0017880ae670</serialNumber>
<UDN>uuid:e17bb69b-7965-4603-bea7-d9bef2aeb3fd</UDN>
<serviceList>
<service>
<serviceType>(null)</serviceType>
<serviceId>(null)</serviceId>
<controlURL>(null)</controlURL>
<eventSubURL>(null)</eventSubURL>
<SCPDURL>(null)</SCPDURL>
</service>
</serviceList>
<presentationURL>index.html</presentationURL>
<iconList>
<icon>
<mimetype>image/png</mimetype>
<height>48</height>
<width>48</width>
<depth>24</depth>
<url>hue_logo_0.png</url>
</icon>
<icon>
<height>120</height>
<width>120</width>
<depth>24</depth>
<url>hue_logo_3.png</url>
</icon>
</iconList>
</device>
</root>
