Can somebody explain me if it is possible to use the old influxdb database feeded by openHAB2 with the new openHAB3? I want to take over all the old item names, but I get the impression by reading here in the forum that this is not possible. Am I right or is there no problem to do it?
Early on in the first milestone releases of OH 3 there was a bug in the new influxdb add-on. That bug has long since been fixed. You should be able to use your old database with OH 3.
Ok, I have tried to configure a connection but I get the following error:
2020-12-17 11:37:39.927 [WARN ] [rnal.influx1.InfluxDB1RepositoryImpl] - database error: java.net.ConnectException: Failed to connect to /192.168.2.110:8086
org.influxdb.InfluxDBIOException: java.net.ConnectException: Failed to connect to /192.168.2.110:8086
at org.influxdb.impl.InfluxDBImpl.ping(InfluxDBImpl.java:395) ~[bundleFile:?]
at org.openhab.persistence.influxdb.internal.influx1.InfluxDB1RepositoryImpl.checkConnectionStatus(InfluxDB1RepositoryImpl.java:86) [bundleFile:?]
at org.openhab.persistence.influxdb.internal.influx1.InfluxDB1RepositoryImpl.connect(InfluxDB1RepositoryImpl.java:72) [bundleFile:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.activate(InfluxDBPersistenceService.java:112) [bundleFile:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.modified(InfluxDBPersistenceService.java:149) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeModifiedMethod(SingleComponentManager.java:836) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:791) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:709) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:673) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:316) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$2.configurationEvent(RegionConfigurationSupport.java:118) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1709) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1651) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
Caused by: java.net.ConnectException: Failed to connect to /192.168.2.110:8086
at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:265) ~[bundleFile:?]
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:183) ~[bundleFile:?]
at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224) ~[bundleFile:?]
at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108) ~[bundleFile:?]
at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88) ~[bundleFile:?]
at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.ping(InfluxDBImpl.java:381) ~[bundleFile:?]
... 26 more
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:403) ~[?:?]
at java.net.Socket.connect(Socket.java:609) ~[?:?]
at okhttp3.internal.platform.Platform.connectSocket(Platform.java:130) ~[bundleFile:?]
at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:263) ~[bundleFile:?]
... 26 more
user ,password and db is the same like in my OH2 config… what is the problem here?
You are right, but I have tried it with a few spaces in front of the http and than you can see the right address in the log but with the same error. Also the same with text file configuration. Seems like a bug of the logging.
The connection was refused… is it possible that only one connection per user to influx is possible? Oh2 is connected and writes data to the openhab database…
I did a minor modification to my previous post.
As far as I can see privileges are required to run “show databases”.
To connect as normal user to a database the db needs to be a separate parameter.
I connected two times with normal user privleges to an openhab influxdb at the same time.
In one of your answers you wrote ( as least that’s how I understand your reply ) that the host contains the http string. The influx command arguments that I provided do not have http in the host name.
e.g. I use
2020-12-18 15:27:01.772 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field “value” on measurement “Network_Rpi_Audio_Attic” is type integer, already exists as type float dropped=1
at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:144) ~[bundleFile:?]
at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
I am running on RC1 with the same influxdb version i used with OH2.
Am i missing something?
Ok, thank you, I think we are coming closer to the problem. On my oh2 machine and your expression with localhost I can connect, but if I am using the ip adress the connection is refused:
Yeah, now it is running, I had to reconfigure the parameter bind address in the influxdb.conf. Now I can use my old database. Thank you very much!
@ysc: I have data from the last 2 years in my database and I can use them for the charts. The last 2 Months and the last 4 Months are running, with loading time, but a plot of a larger time period end with a complete reload of the chart with the predefined time period ( in my case 2 weeks). In grafana the plot is no Probleme and very fast… Do you have any idea what’s the matter?
Can somebody explain how to transfer the influxdb database from openHAB2.5 to openHAB3?
All posts above are about the error, but can’t find the exact steps how to transfer?
