Hi all,
I try to trigger a notification with pushcut. But my syntax seems to be wrong. Can you point me in the right direction?
In a JS 2021 Script I put the following:
var url = 'https://api.pushcut.io/v1/notifications/Restart';
var headers = ('accept:application/json','API-Key:___myKey____','Content-Type:application/json');
sendHttpPostRequest(url, headers,5000);
In the logs I get this:
2023-01-17 02:28:43.836 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID '3751d982bf' failed: ReferenceError: "sendHttpPutRequest" is not defined in <eval> at line number 3
I actually also tried this
HTTP.sendHttpPostRequest(url, headers,5000);
