I’ve just installed my new Satel Integra 128 alarm.
For my Windows I am using wireless detectors. Each window can be fully opened or tilted. Therefore I added a 2nd magetic contact to the wireless detectors:
One contact open means the window is opened
Both contacts open means the window is tilted
Within my panel I created (virtual) zones which show the correct state, so this works fine.
I’ve set the option “Bypass if no exit” for these virtual zones. So when I am leaving the house, I use my keypad downstairs and use Arming Mode Full to arm the system. If a Window is open, it’s shown on the Keypad and I can decide to bypass it at that moment. That’s fine.
When I go to bed, I use the Keypad upstair and I use the mode 1 (Full Arm with Bypasses) so I can open/close (upstairs) Windows without problems. This also seems to work fine.
However in OpenHAB I would like to use this information (Window status) as well. But when I arm the system and one of more of these contact have status violated, they will be bypassed when I arm the system and in OpenHAB I can’t use the information whether the Window is opened/closed anymore. The Violation channel isn’t working anymore (as far as I’ve seen now).
So I now created a new Partition “Technical” with new Virtual Zones following the original contacts. Users will not have permissions to this partition, only the OpenHAB user. The idea is that I never arm this partition, and I use these zones in OpenHAB for the status of the Windows. It looks like this works, but at the cost of some zones and outputs. And I am wondering if this is the way forward or maybe I am making it to complex now.
Anyone suggestions/ideas?
