Hey there,
i want to use a “setting” for an url.
In fact i try to implement the setting (i defined as a string config-element) for this line:
<div class="icon on"><svg viewBox="0 0 48 48"><use xlink:href="/static/matrix-theme/squidink.svg#thermometer-3"></use></svg></div>
I tried it with the following line:
<div class="icon on"><svg viewBox="0 0 48 48"><use xlink:href="{{(config.svg1)}}"></use></svg></div>
But i just get the text of the string displayed in the preview-dialog. I want to hand over the url i defiiened in the svg1 attribut.
Could andybody help me?
namraccr
(namraccr)
August 3, 2017, 2:03am
2
You’re going to have to be a lot more specific.
I don’t grasp what you’re trying to accomplish.
MrBoggi
(Morten Bogetvedt)
August 3, 2017, 6:01am
3
I guess he is trying to replace the url to the svg file with a config variable so that the widget is not hardcoded to use a specific file but a config variable.
MrBoggi,
You are right. This is exactly what i want to do.
Do you have any hints for me?
ysc
(Yannick Schaus)
August 3, 2017, 3:53pm
5
Hey yannick,
Thanks for replying. I tried the mentioned approach but with no result. The svg is just not shown. Do you have another hint?
ysc
(Yannick Schaus)
August 4, 2017, 2:39pm
7
Sorry, none that I can think of right now.
I didn’t buy squidink.svg so can’t have a look either.
namraccr
(namraccr)
August 5, 2017, 2:33am
8
Well in that case how about something like this?
If you have an item named svg1 that contains the url string:
<div class="icon on"><svg viewBox="0 0 48 48"><use xlink:href="{(itemState('svg1')}"></use></svg></div>
As another angle, is there a browser that will render the external svg using this syntax? I haven’t found one…
<html>
<div class="icon on"><svg viewBox="0 0 48 48"><use xlink:href="m2.svg"></use></svg></div>
</html>
