Using the MQTT Broker [Things - Paper UI]
Hi to all,
First, I would like to briefly describe what I have already done (which also works) - then comes the question.
I have set up an MQTT broker in Openhab2 (2.4 - stable version) and added some MQTT Things to test the basic functionality in the Paper UI. In a test file *.sitemap I included the created items. A communication via mqtt works.
Now I do not want to add just 5 items or things but more than 150.
My idea is to create the items in a *.items file, because writing is quicker and easier than clicking on all the items you need (rather, creating them).
How do I get the defined MQTT interface of the MQTT Broker from the Paper UI addressed? I could not find anything suitable on Google. Results show very old 1.x bindings or everything in the Paper UI (which I do not want).
Switch itemname "labeltext" {mqtt="<[HomeAutomationServerMQTTBroker:home/indoor/eg/essen/taster:state:default], >[HomeAutomationServerMQTTBroker:home/indoor/eg/essen/taster:command:*]"}
Thank you in advance
Peter
You need to use channels.
If you prefer to work in files, you may define things and channels in files.
