Hello everyone,
here’s a little example demonstrating how one can use TypeScript to write openHAB Scripts.
All this essentially does is use rollup with its typescript plugin to generate a single javascript file in the IIFE format.
In addition to that, this
is passed to the generated bundle, so it can be used in the Script.
This happens in the package.json
TypeScript defaults to ES5. Considering that Nashorn’s implementation implements ES5.1, no typescript config should be needed.
There is probably a couple of things that could be improved (for example handling this
better). If you have any improvements, please let me know.
The example in the template generates a .js that looks like this :
As the files might change in the future: this is the commit that resulted in the file below.
var ctx = this;
(function () {
'use strict';
var LoggerFactory = /** @class */ (function () {
function LoggerFactory() {
LoggerFactory.getByRuleId = function (ruleId) {
// TypeScript does not know about Java. It does not know that this script will be run in Nashorn.
// As such, it will complain about Java being undefined.
// To fix this, references to "unknown" variables that are available in the script must be
// annotated with a @ts-ignore.
//@ts-ignore
return Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.rule." + ruleId);
return LoggerFactory;
// This is the "main" file. Import modules into here.
// While the following statement will function correctly when uncommented,
// it is discouraged to use "this" directly in the root scope.
//@ts-ignore
this.logger = typeof this.logger === "undefined" ? LoggerFactory.getByRuleId("myRuleId") : this.logger;
// Instead store this in a variable. That way you can add an interface to the variable which will help with autocompletion.
var _this = ctx;
_this.logger = typeof _this.logger === "undefined" ? LoggerFactory.getByRuleId("myRuleId") : _this.logger;
// This will be an object
_this.logger.info("Type of this.Java is {}", typeof _this.Java);
// You can use templating here too. logger references the Java class.
_this.logger.info("Hello, {}!", "World");
// items was declared in openHabRoot.ts
var allItems = _this.itemRegistry.getItems();
// Note that you do not have to prepent _this in front of Java, itemRegistry, etc. TypeScript will just complain about it.
//@ts-ignore
_this.logger.info("Is _this.itemRegistry instanceof ItemRegistry? : {}", _this.itemRegistry instanceof Java.type("org.openhab.core.items.ItemRegistry"));
_this.logger.info("There are {} items.", allItems.size());
EDIT: Moved repository from gitlab over to github
