freshly installed OpenHAB 3 v 1.7.1 two days ago.
Now I’m trying to configure remote-access via myopenhab.org
the registering needs the secret and the UUID.
In a video it was shown that the UUID-file should be in the subfolder
/var/lib/openhab
but there it isn’t
So what do I have to do to create this UUID-file or where else should I look for it?
thank you very much for the link. I was able to install the Cloud-Connector and found the UUID and the Secretfile
I pasted the UUID and secret into registration and received a confirmation email and clicked the confirmation-link
account is created but myopenhab.org says
Your openHAB is not online. Please check if your installation is running or recheck the openHAB settings in your account
OK I found the error myself. As long as no items are exposed the website says “not online”.
So I activated some items to be exposed and now it show openHAB is online.
@the myopenhab.org-team how about a hint that points to this fact? I mean a message like "if not a single item is set to “exposing” the status of your openHAB-system stays offline
There is no defined time, sometimes a restart of openHAB will be helpfull.
And yes, you can disable (unexpose) all items and it should still work.
Exposing was only used for IFTTT, whiach has been disabled a long time ago.
I am usining remote control and notification over myopenHAB wihout any exposed items.
Even Alexa works with correct tagging.
