Hi guys,
when I copy the content of one variable to another in a rule as shown in the code snipped below (Tem_LR = Tem_LR_h), I get the following message in my log file
2017-12-04 09:15:35.421 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'default.rules', using it anyway:
Assignment to final field
The string “Assignment to final field” is repeated for every instance I copy the content to a variable.
Does anyone have an idea how I can get rid of this message?
// Temperature Definitions
// Window open temperature
val Number Tem_WO = 10
// Living Room Temperatures
val Number Tem_LR_h = 20
val Number Tem_LR_l = 18
// Variables to store target temperatures, includes manual changes
// The manual changes will we overwritten according to the timetables
val Number Tem_LR = Tem_LR_h
//Week Plan
rule "SAT-SUN Living Room Morning Heating"
Time cron "0 00 07 ? * SAT-SUN *"
if(Tem_LR < Tem_LR_h)
Tem_LR = Tem_LR_h
if(Contact_Shutter_LR.state == CLOSED)
sendCommand(SetTemperature_Thermostat_LR, Tem_LR)
logInfo("rule", "SAT-SUN Living Room Morning Heating started")
else
logInfo("rule", "SAT-SUN Living Room Morning Heating Temperature set but not started since window is open.")
else
logInfo("rule", "SAT-SUN Living Room Morning Heating not started since temperature is already equal or higher.")
- Platform information:
- Hardware: Raspberry Pi 3
- OS: openhabianpi-raspbian-201706161358-git7ff273e-crc00389b9f.img
- Java Runtime Environment: not sure, I didn’t change anything from the installed OS
- openHAB version: 2.1.0 release build
Thank you very much for your replies!
