Value of CurrentTemperature Item not displayed in Alexa
I have problems in showing current temperature values from my thermostat or weather sensor in alexa. I use myopenhab to synchronize my items with alexa, and usually everything works well.
I have created items in openhab and assigned Thermostat.CurrentTemperatre as Alexa Metadata.I also tried Other.CurrentTemperature …
The item is displayed in the Alexa app, but either I get an error message (“Etwas ist schiefgelaufen") with a Try Again button, or I see a Thermostat screen with a “-” as current Temperature.
In Openhab, the current temperature is displayed correctly. Some weeks ago it still worked well. Deleting and creating the items again does not help. Does someone have a hint on what I could try to send the temperature values to Alexa correctly?
Thank you and best regards!
Plattform information:
  • Openhab 5.0.3
  • Linux/5.15.0-161-generic (amd64)
  • Java 21.0.9 (Zulu21.46+19-CA)
Unfortunately I have - more or less - the same issue. I used it to provide the current value of my floating energy tariff and it worked like a charm for years. Unfortunately, since a few weeks, Amazon Alexa does not receive any update for this particular value.
This is how my configuration looks like:
Number:Dimensionless EPEX_SPOT_currentgross_ALEXA "Aktueller Strompreis [%2.2f ct/kWh]" { channel="awattar:prices:strastra:awattar_price:current#market-gross", alexa="RangeValue" [capabilityNames="Aktueller Strompreis", supportedRang="0:10000:1", nonControllable=true] }
I am on OH 4.3.8 and have the same issue. If i set such a value from “nonControllable ON” (read only) to “nonControllable OFF” within OH Alexa metadata, i get a slider in Alexa which can change the values in OH. This is strange and here something is definetely wrong. But it proves that the basic connection between OH and Alexa is working out. Switch items work out normal.
Before i came from OH 3.4.6 were everything worked fine over years. I don’t know who is the owner of the Alexa integration?
Unfortunately no further reaction here. Have linked another thread where i placed my observation.
Experiencing same issue on 4.3.10, temperature related items are not being reported byAlexa but light switches, and other devices are working as expected. Anyone been able to solve this?
same problem. OH Version 4.3.10. Temperaturesensor are not updated in Alexa. Everything else seems to work. See also OH 4.3.8 / 5.0.3 item states are not updated in Alexa · Issue #820 · openhab/openhab-alexa · GitHub . Any workaround/solution known? O.
Yes, there is no solution yet because the discontinued reading of item states is an Amazon issue. In the meantime i moved from the direct openHAB Alexa skill to the Matter binding. The Matter bridge can expose almost every item to Alexa. No need for the device to be Matter compatible, means even older devices with no Matter pairing code are working so. This works out for command items as well as for reading of item states. I got even my 12 years old heater thermostats working through Matter.
After installation of the Matter binding and pairing the bridge with Alexa, you need to set metadata “Matter” for the items you want to expose to Alexa.
Thx. But Matter support is not available for my OH4.3.10., correct?
You wrote “because the discontinued reading of item states is an Amazon issue.” But why is the Matter Binding able to overcome this obstacle?
I am on OH 5.3.0.M3 and don’t know if it can work on your version. Check if the Matter binding occurs if you if you go to the “Add-on Store”.
The answer to your 2nd question: Matter is a standard and the Matter binding as well as Amazon follow this standard. The way that the openHAB Alexa skill applies is different. Such sensors/item states are obviously filtered or no longer supported by Amazon. For further details, i am not the expert.
