This issue is fixed within PR#5843 . Hope that it will be incorporated soon.
Nope, I always use items files, because I have had troubble with paperUI items before⌠Never again⌠So the last year or more, I have been using items files only.
Is this also an issue⌠I just setup my scenes as well, which I use in a rule⌠But when the scene activates, this happen:
2019-04-23 19:48:41.297 [ome.event.ItemCommandEvent] - Item 'VeluxAlleAaben100' received command ON
2019-04-23 19:48:41.302 [vent.ItemStateChangedEvent] - VeluxAlleAaben100 changed from NULL to ON
2019-04-23 19:48:41.308 [GroupItemStateChangedEvent] - gV changed from NULL to ON through VeluxAlleAaben100
2019-04-23 19:48:42.055 [ome.event.ItemCommandEvent] - Item 'VeluxAlleAaben100' received command OFF
2019-04-23 19:48:43.321 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.332 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.341 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.352 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.362 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.374 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.385 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.393 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:48:43.398 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.403 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.408 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.413 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.418 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.423 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.428 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:48:43.433 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_REMAINING_TIME_NTF, continuing.
2019-04-23 19:49:08.449 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:09.425 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:10.439 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:11.423 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:12.422 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:13.422 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:14.474 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:15.462 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_COMMAND_RUN_STATUS_NTF, continuing.
2019-04-23 19:49:15.466 [WARN ] [binding.velux.bridge.slip.SCrunScene] - setResponse(): received GW_SESSION_FINISHED_NTF.
2019-04-23 19:49:15.468 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item VeluxAlleAaben100 (type SCENE_ACTION) failed.
All the windows do open fine thoughâŚ
This is my items file:
/* Velux Bridge and Devices */
String V_FIRMWARE "Firmware [%s]" {velux="thing=bridge;channel=firmware"}
String V_STATUS "Status [%s]" {velux="thing=bridge;channel=status"}
String V_CHECK "Velux Config Check [%s]" { velux="thing=bridge;channel=check" }
Rollershutter Vindue01 "Vindue stue syd-øst 1 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:29:06:C7" }
Rollershutter Vindue02 "Vindue spisestue øst 2 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:30:0A:CD" }
Rollershutter Vindue03 "Vindue stue nord-øst 3 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:29:12:03" }
Rollershutter Vindue04 "Vindue køkken syd-øst 4 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:29:08:7B" }
Rollershutter Vindue05 "Vindue stue syd-vest 5 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:29:14:5B" }
Rollershutter Vindue06 "Vindue spisestue vest 6 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:30:0C:A1" }
Rollershutter Vindue07 "Vindue køkken nord-øst 7 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:29:0D:0D" }
Rollershutter Vindue08 "Vindue stue nord-vest 8 [%d]" { velux="thing=actuator;channel=serial#56:08:1D:26:06:29:14:5C" }
// Velux Scene channels
Switch VeluxAlleLuk "Luk alle vinduer" <window> (gV) { velux="thing=scene;channel=action#AlleVinduerLuk" }
Switch VeluxAlleAaben50 "Ă
ben alle vinduer 50%" <window> (gV) { velux="thing=scene;channel=action#AlleVinduer50" }
Switch VeluxAlleAaben75 "Ă
ben alle vinduer 75%" <window> (gV) { velux="thing=scene;channel=action#AlleVinduer75" }
Switch VeluxAlleAaben100 "Ă
ben alle vinduer 100%" <window> (gV) { velux="thing=scene;channel=action#AlleVinduer100" }
Switch VeluxAlleVent "SĂŚt alle vinduer pĂĽ ventilation" <window> (gV) { velux="thing=scene;channel=action#AlleVinduerVent" }
// Køkken
Switch VeluxKoekAlleLuk "Køkken Luk alle" <window> (gV) { velux="thing=scene;channel=action#KoekkenLuk" }
Switch VeluxKoekAlleVent "Køkken vent alle" <window> (gV) { velux="thing=scene;channel=action#KoekkenVent" }
Switch VeluxKoekAlle50 "Køkken üben alle 50%" <window> (gV) { velux="thing=scene;channel=action#Koekken50" }
Switch VeluxKoekAlle75 "Køkken üben alle 75%" <window> (gV) { velux="thing=scene;channel=action#Koekken75" }
Switch VeluxKoekAlle100 "Køkken üben alle 100%" <window> (gV) { velux="thing=scene;channel=action#Koekken100" }
// Spisestuen
Switch VeluxSpisAlleLuk "Spisestue luk alle" <window> (gV) { velux="thing=scene;channel=action#SpisestueLuk" }
Switch VeluxSpisAlleVent "Spisestue vent alle" <window> (gV) { velux="thing=scene;channel=action#SpisestueVent" }
Switch VeluxSpisAlle50 "Spisestue ĂĽben alle 50%" <window> (gV) { velux="thing=scene;channel=action#Spisestue50" }
Switch VeluxSpisAlle75 "Spisestue ĂĽben alle 75%" <window> (gV) { velux="thing=scene;channel=action#Spisestue75" }
Switch VeluxSpisAlle100 "Spisestue ĂĽben alle 100%" <window> (gV) { velux="thing=scene;channel=action#Spisestue100" }
// Stuen
Switch VeluxStueAlleLuk "Stuen luk alle" <window> (gV) { velux="thing=scene;channel=action#StueLuk" }
Switch VeluxStueAlleVent "Stuen vent alle" <window> (gV) { velux="thing=scene;channel=action#StueVent" }
Switch VeluxStueAlle50 "Stuen ĂĽben alle 50%" <window> (gV) { velux="thing=scene;channel=action#Stue50" }
Switch VeluxStueAlle75 "Stuen ĂĽben alle 75%" <window> (gV) { velux="thing=scene;channel=action#Stue75" }
Switch VeluxStueAlle100 "Stuen ĂĽben alle 100%" <window> (gV) { velux="thing=scene;channel=action#Stue100" }
Based on Guentherâs recommendation I bought a KLF200âŚ
⌠but unfortunately now I canât see the binding available for download into OpenHab 2 (i.e. its not in the legacy 1.14 list of bindings of PaperUI âŚ
⌠so where can I get it please?
Hello @AndrewFG,
the binding should be within the 1.14 distribution⌠or you can find the jar-file within gs4711@github.
Regards, Guenther
Thanks Guenther. I will start working with it. At the moment, it seems that the only available OpenHab runtime for testing purposes is v2.4. So is it correct that your plugin will work if I drop the JAR file into the OpenHab addons folder (and create respective .config. and .items files)? Or do I need to do something else?
Correct: just create the config files and put the jarfile into the additional folder. If it does not work from the beginning, try to increase the loglevel which will lead to tons of addtional informations.
Regards, Guenther
Hi Guenther, I have been away from home, so have not made any progress. But I will let you know.
Hi Guenther,
Ok, I tried your binding just now, and I do get âsomethingâ but actually it is all errors
â see belowâŚ
( note: it is a brand new KLF200 unit, with v2.x firmware in it, and with the default password etc. )
2019-05-15 19:00:16.664 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2019-05-15 19:00:26.661 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'velux.items'
2019-05-15 19:00:27.726 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'velux.items'
2019-05-15 19:01:18.141 [INFO ] [inding.velux.internal.VeluxActivator] - velux binding has been started.
2019-05-15 19:01:18.666 [INFO ] [.binding.velux.internal.VeluxBinding] - Active items are: [V_FIRMWARE, V_CHECK, V_STATUS].
2019-05-15 19:01:18.684 [INFO ] [.binding.velux.internal.VeluxBinding] - velux refresh interval set to 15000 milliseconds.
2019-05-15 19:01:18.689 [INFO ] [.binding.velux.internal.VeluxBinding] - veluxConfig[bridgeProtocol=slip,bridgeIPAddress=192.168.1.142,bridgeTCPPort=51200,bridgePassword=********,timeoutMsecs=1000,retries=5,refreshMsecs=15000,isBulkRetrievalEnabled=true]
2019-05-15 19:01:18.704 [INFO ] [b.core.service.AbstractActiveService] - velux Refresh Service has been started
2019-05-15 19:01:18.756 [INFO ] [g.velux.bridge.slip.io.SSLconnection] - Starting velux bridge connection.
2019-05-15 19:01:24.806 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:01:25.848 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:01:26.900 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:01:27.924 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:01:43.940 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:01:44.957 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:02:00.972 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:02:01.988 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:02:18.126 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:02:19.169 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:02:35.184 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:02:36.203 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:02:52.225 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:02:53.239 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:03:09.250 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:03:10.261 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:03:26.271 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:03:27.286 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:03:43.296 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:03:44.310 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:04:00.325 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:04:01.341 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:04:17.354 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:04:18.368 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:04:34.386 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:04:35.399 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:04:51.408 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:04:52.419 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:05:08.440 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:05:09.447 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:05:25.458 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:05:26.472 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:05:41.476 [DEBUG] [.binding.velux.internal.VeluxBinding] - execute() called.
2019-05-15 19:05:41.480 [DEBUG] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(item=V_STATUS,command=null,config=org.openhab.binding.velux.internal.VeluxBindingConfig@1ff6dd2,provider=org.openhab.binding.velux.internal.VeluxGenericBindingProvider@1389c1d) called.
2019-05-15 19:05:41.483 [DEBUG] [.velux.handler.VeluxBridgeHandlerOH1] - bridgeParamsUpdated() called.
2019-05-15 19:05:41.486 [DEBUG] [.velux.handler.VeluxBridgeHandlerOH1] - bridgeParamsUpdated(): choosing SLIP as communication method.
2019-05-15 19:05:41.492 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(GW_PASSWORD_ENTER_REQ,unauthenticated) called.
2019-05-15 19:05:41.495 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(): working on request GW_PASSWORD_ENTER_REQ with 32 bytes of data.
2019-05-15 19:05:41.506 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - io(): sending packet of size 39.
2019-05-15 19:05:42.511 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - io(): received packet with 8 bytes.
2019-05-15 19:05:42.517 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(): working on response GW_PASSWORD_ENTER_CFM with 1 bytes of data.
2019-05-15 19:05:42.521 [DEBUG] [ab.binding.velux.bridge.slip.SClogin] - setResponse(GW_PASSWORD_ENTER_CFM with 1 bytes of data) called.
2019-05-15 19:05:42.524 [DEBUG] [ab.binding.velux.bridge.slip.SClogin] - setResponse(): returned status: The request failed.
2019-05-15 19:05:42.528 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(GW_PASSWORD_ENTER_REQ) returns failure.
2019-05-15 19:05:42.532 [WARN ] [.velux.handler.VeluxBridgeHandlerOH1] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2019-05-15 19:05:42.536 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(GW_PASSWORD_ENTER_REQ,unauthenticated) called.
2019-05-15 19:05:42.540 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(): working on request GW_PASSWORD_ENTER_REQ with 32 bytes of data.
2019-05-15 19:05:42.551 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - io(): sending packet of size 39.
2019-05-15 19:05:43.555 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - io(): received packet with 8 bytes.
2019-05-15 19:05:43.565 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(): working on response GW_PASSWORD_ENTER_CFM with 1 bytes of data.
2019-05-15 19:05:43.567 [DEBUG] [ab.binding.velux.bridge.slip.SClogin] - setResponse(GW_PASSWORD_ENTER_CFM with 1 bytes of data) called.
2019-05-15 19:05:43.570 [DEBUG] [ab.binding.velux.bridge.slip.SClogin] - setResponse(): returned status: The request failed.
2019-05-15 19:05:43.573 [DEBUG] [ng.velux.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(GW_PASSWORD_ENTER_REQ) returns failure.
2019-05-15 19:05:43.575 [INFO ] [.velux.handler.VeluxBridgeHandlerOH1] - handleCommandOnChannel(): updating of item V_STATUS (type BRIDGE_STATUS) failed.
2019-05-15 19:05:43.580 [DEBUG] [.binding.velux.internal.VeluxBinding] - execute() done.
2019-05-15 19:05:58.584 [DEBUG] [.binding.velux.internal.VeluxBinding] - execute() called.
thanks for this part of the log. In fact, youâre only a minor step away from a well-working config:
You have already a well-functioning connectivity to the KLF200 bridge - but youâre simply using a wrong password. Please try the default password.
Greetings, Guenther
Hi Guenther,
Many thanks, I got it working now.
However I do have already a few feedbacks as followsâŚ
In the documentation you refer to the hub configuration file as âopenhab.cfgâ and you should change this in the documentation to âvelux.cfgâ
You should make it more explicit in the documentation that the password to use in the velux.cfg file is label on the back of the KLF called âPasswordâ (wifi password) and not the Web logon âpasswordâ (velux123)
The position status scale of the velux windows is very confusing â it shows 100% when the window is closed, and 0% when it is open. I think you should reverse the scale.
When one issues a manual command to set a new position of the window, one has to wait for the Refresh Interval before the actual new status is indicated. It would be better to have a fast feedback indication that the command has been received. One idea would be to do it like a thermostat where there are two datapoints - namely âSet Positionâ and âActual Positionâ; the Set Position is what is sent to the hub as a command (SET_STATE), and the Actual Position is what you get back when you query its status (GET_STATE). It could also be helpful if the Refresh Interval would be temporarily shortened after any manual Set Position commands are sent.
The hub variables âfirmwareâ and âcheckâ do not work. However the variable âstatusâ does seem to work Ok.
EDIT: regarding item 4. above, when I issue a manual command from openHAB basic UI to open the window to 50%, I see the following series of events. I suppose the first â100 to 50â event is the initial manual command; all of the subsequent â50 to 100â and â100 to 50â events are spuriousâŚ
2019-05-16 16:47:55.163 [vent.ItemStateChangedEvent] - V_LOFT changed from 100 to 50
2019-05-16 16:47:55.182 [vent.ItemStateChangedEvent] - V_LOFT changed from 50 to 100
2019-05-16 16:47:55.201 [vent.ItemStateChangedEvent] - V_LOFT changed from 100 to 50
2019-05-16 16:48:11.078 [vent.ItemStateChangedEvent] - V_LOFT changed from 50 to 100
2019-05-16 16:51:42.127 [vent.ItemStateChangedEvent] - V_LOFT changed from 100 to 50
First of all, thank you @gs4711 for this great binding! I used the version for the firmware version One for a while now and upgraded my KLF 200 to the new firmware - really glad that the windows can be controlled directly now and I can leave behind the scene fiddling.
That being said, I can confirm what @AndrewFG already described: When I set a new window position the item changes back to the previous state after the window movement is complete. But again, after some minutes, it changes again to the position that I actually set. In the following case, the window was closed and I set the item to â48% closedâ. For this operation, for events have been logged:
2019-05-17 16:26:05.549 [ome.event.ItemCommandEvent] - Item 'Fenster_Buero' received command 48
2019-05-17 16:26:05.566 [vent.ItemStateChangedEvent] - Fenster_Buero changed from 100 to 48
2019-05-17 16:26:31.046 [vent.ItemStateChangedEvent] - Fenster_Buero changed from 48 to 100
2019-05-17 16:29:13.293 [vent.ItemStateChangedEvent] - Fenster_Buero changed from 100 to 48
Thanks for the feedback. Which version of the binding are you using? Should have been fixed with PR#5843.
This might be an embarrassing question - but how/where can I download the most recent version?
The one I downloaded and use is the one you linked to here:
That is the latest .jar file as far as I can see. I use the same, and ofcouse have the exact same issues.
@gs4711 I guess there is a need to an updated jar
Hhhhm. Sorry guys, perhaps youâre right.
I have to check the mentioned build against the two not yet merged open PRs.
I donât know what makes the difference, but on my KLF200 the WIFI password did not work, I had to use velux123, which took me some time to find out I have not changed any passwords on the KLF200. So the documentation should probably state to try both, since apparently it depends on HW revision.
I think this should be somehow configurable, because although it seems confusing with the window it makes sense when considering we are controlling a ârollershutterâ item (the icon shows the rollershutter fully closed when at 100%, and fully open when at 0%).
I also have a couple of MML awning blinds, which show 100% when the blinds are closed and 0% when they are open. That seems logical for awning blinds (and probably some other items).
Also, for the windows, there is the âventilationâ position, where the window is closed, but you still get some fresh air. Does this map to a special setting on the item? I guess if the position status scale is reversed so 0% is closed and 100% is fully open, then 1% would make some sense for the ventilation position?
Cheers
To me it doesnt really make any sense at all.
0 (zero) should have the meaning of the default state. If you believe your rullershutter, blinds, etc has the default state of beeing closed, then yes, zero makes sense. But I honestly dont think this is a normal opinion.
As for windows, default state is closed. So for this to get any sense, anything else than closed should be open. And then, how much it´s open, (ie something between 1 - 100).
I wonder what sense you´ll give ligthing (dimmer) then? 0 = full light?
Again, default state is it´s turned off. It doesn´t make sense this beeing reported as 100%.
I sure wish we could get this changed to what would be correct for the most.
Rollershutter and blinds are open by default, and can be controlled closed from 1 to 100%.
Windows, lights etc are OFF by default. And can be controlled lit from 1 to 100%.
I could live with an option of setting an inverted default state through the binding though. But we have to have the correct way to controle these things, from 1 - 100%. And not the other way around.
Then it doesnt matter, if you through the binding set your rollershutter to be closed state as default. You´ll still use 1 to 100% to open it.
I dont know if Guenther (@gs4711) have had any thoughts about this?
You donât need to be sarcastic - it just makes it appear like you didnât understand what I wrote. Iâm not suggesting changing the meaning of light dimmers (unless you get the darkness-bulbs the make the room darker when you turn them on; they are much more environmentally friendly )
I donât know what you mean by the default state. In my opinion the most logical for windows would be 0%=closed and 100%=fully open. What I was referring to when I wrote âit makes senseâ is that the Item in OpenHAB is a âRollershutterâ, and the sitemap icons for rollershutters show them fully closed at 100% and fully open at 0%. In fact I think that the problem is to a wide extent related to the limited number of item types in OpenHAB, and not really a problem with the binding. This is a window, not a rollershutter, but still the best OpenHAB item type currently available is a rollershutter.
And secondly, the reason why I think the âreversingâ needs to be configurable is exactly because of my awning blinds. To me it seems most logical that 0% is that the blinds are open (I can look out the window), and 100% is closed (limits the heating from the sun), and that is exactly how it is working now. I mentioned it because maybe Guenther does not have such blinds, so he would not be aware that just reversing the direction of all items is not a good idea.
Cheers
