Hi, I’m trying to install the new official Verisure Binding but have run into a problem. The Verisure binding is shown in the overview of bindings but when I want to install it on my server it does not appear in the overview I get in paper ui. Is there anyone who can help?
Place the jar file in /usr/share/openhab2/addons then restart OH. Also make sure the file has proper permissions. This can be done via openhabian config tool just look for the fix permissions option.
You are correct just use the same link and install the latest jar file if an update is needed. Not sure what version of OH your using but if on 2.5 then any of the ones listed except the 3.0 should work.
Also, if the binding becomes available via PaperUI and you want to install that way then you will need to remove the manual installed version as any jar file in the addons file takes priority.
Good morning, I have installed this binding and I get this error, I have tried it by installing from the paper-ui and then manual and it always comes out the same, use OH2 (updated correctly) I attach the screenshot
