I recently upgraded to OH 3.
I have the following bindings:
- avmfritz
- harmonyhub
- sonos
- tradfri
After a couple of hours of running without issues, OH does no longer react when I turn on or off things, or rules are no longer triggered.
I need to restart OH, then it works again for a couple of hours, and so on.
Same error in M2, and in 3.0. How can I look for the source of the error? In the log, the followin occurs when OH is no longer reacting on switches etc.:
2021-04-12 20:05:02.170 [WARN ] [apache.cxf.jaxrs.utils.ResourceUtils] - No resource methods have been found for resource class javax.ws.rs.core.Response
2021-04-12 20:05:02.331 [WARN ] [apache.cxf.jaxrs.utils.ResourceUtils] - No resource methods have been found for resource class javax.ws.rs.core.Response
2021-04-12 21:15:03.285 [WARN ] [apache.cxf.jaxrs.utils.ResourceUtils] - No resource methods have been found for resource class javax.ws.rs.core.Response
2021-04-12 21:15:03.340 [WARN ] [apache.cxf.jaxrs.utils.ResourceUtils] - No resource methods have been found for resource class javax.ws.rs.core.Response
2021-04-12 21:16:03.507 [WARN ] [pache.cxf.jaxrs.sse.SseEventSinkImpl] - There are still SSE events the queue which may not be delivered (closing now)
In addition, right after re-starting OH, I get these messages:
2021-04-12 06:04:53.745 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://192.168.178.30:80/description.xml}WebClient has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:67) ~[bundleFile:1.0.9]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.AbstractClient.doRunInterceptorChain(AbstractClient.java:705) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.WebClient.doChainedInvocation(WebClient.java:1081) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.WebClient.doInvoke(WebClient.java:927) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.WebClient.doInvoke(WebClient.java:896) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.WebClient.invoke(WebClient.java:461) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.SyncInvokerImpl.method(SyncInvokerImpl.java:135) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.SyncInvokerImpl.method(SyncInvokerImpl.java:130) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.SyncInvokerImpl.get(SyncInvokerImpl.java:50) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.client.spec.InvocationBuilderImpl.get(InvocationBuilderImpl.java:88) [bundleFile:1.0.9]
at org.openhab.io.hueemulation.internal.upnp.UpnpServer.performAddressTest(UpnpServer.java:252) [bundleFile:?]
at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:642) [?:?]
at java.util.concurrent.CompletableFuture$Completion.run(CompletableFuture.java:478) [?:?]
Caused by: java.net.ConnectException: ConnectException invoking http://192.168.178.30:80/description.xml: Verbindungsaufbau abgelehnt (Connection refused)
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.mapException(HTTPConduit.java:1402) ~[bundleFile:1.0.9]
at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.close(HTTPConduit.java:1386) ~[bundleFile:1.0.9]
at org.apache.cxf.io.AbstractWrappedOutputStream.close(AbstractWrappedOutputStream.java:77) ~[bundleFile:1.0.9]
at org.apache.cxf.transport.AbstractConduit.close(AbstractConduit.java:56) ~[bundleFile:1.0.9]
at org.apache.cxf.transport.http.HTTPConduit.close(HTTPConduit.java:673) ~[bundleFile:1.0.9]
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:63) ~[bundleFile:1.0.9]
... 14 more
