VertiCal Family Calendar
Dear all,
after trying and not finding what I needed for my purpose I decided to create my own family calendar. As a normal family calendar with vertical design would do, it summarizes four people and a family group (in my case, but the code is obviously editable) and it displays the next 3 days.
It uses the iCalendar Binding and is meant for a wall-mounted tablet to show always the next events of the family.
At the moment, there are some minor fixes needed, therefore it is still beta. But it is already useable and should be ok for now.
At the moment, 4 people + a family calendar are used. In the props, they can all be defined.
The calendar items have to be created using the iCalendar binding and setting up the eventfilter things for the next days.
How to create the appropriate items:
It is important to maintain the nomenclature in order to make it working and it is useful to create the thing as eventfilter for every day (10 events max for every day).
  • Create your iCalendar thing subscribing to your calendar (e.g.; “Matthias”)
  • Create a thing “eventfilter” with maximum 10 matches for every single day
  • The item nomenclature for Calendar “Matthias” should be :(Title of the appointment of result 0 of today is
    “Calendar_Matthias_Events_Today_Result_0_Title”,
    “Calendar_Matthias_Events_Today_Result_0_Begin”,
    “Calendar_Matthias_Events_Today_Result_0_End”.
    for tomorrow, the things are called
    “Calendar_Matthias_Events_Tomorrow_Result_0_Title”… and so on
    The day after they are called
    “Calendar_Matthias_Events_Plus2_Result_0_Title”, and so on.
There are some things and to do’s, and surely it is very demanding since there are many items needed. It does sometimes slow down some browser, but it works for me.
To do’s:
  • I would like to add weather info under the Dates in the left column
  • The first column, first row has not the same height as the other ones and I still can’t figure out why (i.e, in the screenshot, the “Matthias” box in the left upper corner should be high as “Gabriel”, “Familie” and the others
I hope you can use the widget and enjoy it.
Changelog
Version 0.1
  • initial release
Version 0.2
  • changed github link and filemame to .yml
Resources
The code is too long to post in this topic, therefore I included the github repository link.
Feel free to help improving, I would appreciate any help!
Github repository
thank you for that widget. Possible to share a snippet of your .items and .things?
I would like to understand the naming convention. I dont get it running.
Regards,
Dee Zett.
EDIT: I made out. Great widget!
the link should also be changed :slight_smile:
Best regards
Thanks for the hint!
I edited the filename but did not update the link. Now it’s working again :grinning:
Hello i’m totally noob with calendars.
Could someone give more explanation about these two steps please?
Hi @Pastroboy ,
first of all you need the iCalendar binding . Install it and create a Thing where you subscribe to your icalendar. Then you can create the eventfilter
Hey, it’s me again. =)
What I’ve noticed during the usage of the calendar widget (still :heart: it so much) is, that after the switch to the next day at 0:00 o clock, top row does not disappear. My solution - running on Linux - is to use xdotool and perform virtual key F5 for browser refresh at 0:00.
On picture below: green has the correct date and red is the wrong one.
Hi @DeeZett,
Great Input thank you!
I still use it too on a Wall-mounted ipad sing Kiosker pro, which is refreshing it at fixed times- therefore did not experience this error.
But thanks for the fix!!
Best,
Matthias
@Matthew1988
Hi!
I’d really like to use your widget but it’s hard for those who don’t know how to use event filter properly.
When I copy/paste the code in a new layout page, openhab asks me for a label name to that page.
I also don’t understand the naming convention. How can I setup an item that will be the 2nd event of One day? In your explanation you explain how to make the item for 1 event for today and then one for tomorrow but how to make a 2nd event for today for example?
Thank you very much!
@Pastroboy
Hi!
I have the same problem, with the second event of One day…
Have you found a solution?
No :frowning: i’ve migrated to an paid app Family wall that fulfills all my needs.
