Because tado is now limiting the allowed API calls to 100 per day, I decided to remove my tado binding. @AndrewFG is working on a HomeKit binding, which will one day restore most of the features, but as that is a big task, that won’t be for the immediate future, I assume.
Coincidentally, I was working on a script to make making schedules (relatively) easier, and I decided to add the functionality to set temperatures as well.
This is my python code: GitHub - ErikDB87/tado-manual-control.
I then made a group item (tado_manual_items_group), in which I put all my items which were linked to the channels targetTemperature and operationMode.
I then wrote this rule:
configuration: {}
triggers:
- id: "1"
configuration:
groupName: tado_manual_items_group
type: core.GroupCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript
script: >-
// All "zone" things have to be removed. Or maybe just the channel
links. But since I had already removed the binding, I couldn't do that
anymore.
var itemnaam = event.itemName;
var nieuwestatus = event.getItemCommand().toString();
var tadozones = {
// The zone id's must be strings
"eetkamer": "2",
"studieruimte": "3",
"badkamer": "5",
"keuken": "6",
"gang_gelijkvloers": "8",
"dressing": "9"
var kamer = itemnaam.split("_")[1];
if (itemnaam.split("_").length > 3) {
kamer = kamer.concat("_").concat(itemnaam.split("_")[2]);
var itemsoort = itemnaam.split("_")[itemnaam.split("_").length-1];
var zone = tadozones[kamer];
var pythoninvenv =
'/var/lib/openhab/bin/python/tado-manual-control/venv/bin/python';
var pythonscript =
'/var/lib/openhab/bin/python/tado-manual-control/tado-manual-control.py';
function callPython(command) {
var pythonOutput = actions.Exec.executeCommandLine(time.Duration.ofSeconds(3), command);
console.log("python output = "+pythonOutput);
function main() {
if (itemsoort == "targetTemp") {
var command = [pythoninvenv, pythonscript, 'manualtemp', '-t', nieuwestatus, '-z', zone];
callPython(command);
} else if (nieuwestatus == "SCHEDULE") {
var command = [pythoninvenv, pythonscript, 'back_to_schedule', '-z', zone];
main();
type: script.ScriptAction
I discovered the links to the channels had to be removed, otherwise the item states couldn’t be changed. I should have done that before removing the binding, so I ended up removing the things altogether…
I thought I’d share this, maybe someone else finds it useful.
I haven’t done a lot of alpha testing, so any improvement suggestions are welcome (both to the python code as to the rule), of course!
(Apologies for the Dutch variables, but I assume that won’t be a deal breaker.
I also had to do some patch work for an ill-advised item name. Obviously the “item name” part will need personalization in any setup.)
