Hi @rtuck99
I am having several exceptions in my log file several times during the day (probably due to my ISP changing the dynamic IP WAN address).
I have tried to understand the behaviour:
Probably when the binding fails to connect to the Viessmann cloud service, the binding sends the first two exceptions (I have two THINGS attached to the BRIDGE)
Unable to request features from IoT API
Then for every ITEM defined for the two THINGS I get the next group of exceptions:
Unexpected exception handling command REFRESH for channel CHANNEL_NAME java.util.concurrent.CompletionException: java.util.concurrent.RejectedExecutionException: Thread limit exceeded replacing blocked worker
Maybe instead of raising an exception, the binding should set to OFFLINE all the THINGS so that no queries will be sent to the cloud when there is no connection, avoiding pages of exceptions. What do you think?
2023-08-18 09:00:58.431 [WARN ] [ar.vicare.internal.VicareServiceImpl] - Unable to request features from IoT API
java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@a9ed3b::DecryptedEndPoint@785e84{l=/192.168.88.5:38716,r=api.viessmann.com/20.166.96.40:443,OPEN,fill=-,flush=-,to=1116127/0}
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:730) ~[?:?]
at com.qubular.vicare.internal.VicareServiceImpl.getFeatures(VicareServiceImpl.java:233) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareBridgeHandler.lambda$getFeatures$8(VicareBridgeHandler.java:236) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1700) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.exec(CompletableFuture.java:1692) ~[?:?]
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290) ~[?:?]
at java.util.concurrent.ForkJoinPool$WorkQueue.helpAsyncBlocker(ForkJoinPool.java:1144) ~[?:?]
at java.util.concurrent.ForkJoinPool.helpAsyncBlocker(ForkJoinPool.java:3151) ~[?:?]
at java.util.concurrent.CompletableFuture.waitingGet(CompletableFuture.java:1817) ~[?:?]
at java.util.concurrent.CompletableFuture.join(CompletableFuture.java:2043) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareBridgeHandler.handleBridgedRefreshCommand(VicareBridgeHandler.java:181) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareDeviceThingHandler.syncHandleCommand(VicareDeviceThingHandler.java:169) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareDeviceThingHandler.lambda$handleCommand$3(VicareDeviceThingHandler.java:159) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1736) [?:?]
at java.util.concurrent.CompletableFuture$AsyncRun.exec(CompletableFuture.java:1728) [?:?]
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290) [?:?]
at java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1020) [?:?]
at java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1656) [?:?]
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1594) [?:?]
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:183) [?:?]
Caused by: java.io.EOFException: HttpConnectionOverHTTP@a9ed3b::DecryptedEndPoint@785e84{l=/192.168.88.5:38716,r=api.viessmann.com/20.166.96.40:443,OPEN,fill=-,flush=-,to=1116127/0}
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:385) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1620) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:269) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:185) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
at java.lang.Thread.run(Thread.java:829) ~[?:?]
java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@a8ff3::DecryptedEndPoint@14ffbe3{l=/192.168.88.5:38714,r=api.viessmann.com/20.166.96.40:443,OPEN,fill=-,flush=-,to=1116181/0}
Caused by: java.io.EOFException: HttpConnectionOverHTTP@a8ff3::DecryptedEndPoint@14ffbe3{l=/192.168.88.5:38714,r=api.viessmann.com/20.166.96.40:443,OPEN,fill=-,flush=-,to=1116181/0}
2023-08-18 09:01:00.358 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_name_name
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:314) ~[?:?]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:319) [?:?]
at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1739) [?:?]
Caused by: java.util.concurrent.RejectedExecutionException: Thread limit exceeded replacing blocked worker
at java.util.concurrent.ForkJoinPool.tryCompensate(ForkJoinPool.java:1575) ~[?:?]
at java.util.concurrent.ForkJoinPool.managedBlock(ForkJoinPool.java:3115) ~[?:?]
at java.util.concurrent.CompletableFuture.waitingGet(CompletableFuture.java:1823) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1736) ~[?:?]
... 6 more
2023-08-18 09:01:00.366 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_modes_active_value
... 6 more
2023-08-18 09:01:00.372 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_modes_heating_active
... 6 more
2023-08-18 09:01:00.378 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_modes_standby_active
... 6 more
2023-08-18 09:01:00.383 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_active_value
... 6 more
2023-08-18 09:01:00.391 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_comfort
... 6 more
2023-08-18 09:01:00.397 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_comfortEnergySaving_active
... 6 more
2023-08-18 09:01:00.403 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_comfortEnergySaving_demand
... 6 more
2023-08-18 09:01:00.408 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_comfortEnergySaving_reason
... 6 more
2023-08-18 09:01:00.413 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_comfort_active
... 6 more
2023-08-18 09:01:00.419 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_comfort_temperature
... 6 more
2023-08-18 09:01:00.425 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_forcedLastFromSchedule_active
... 6 more
2023-08-18 09:01:00.431 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_normal
... 6 more
2023-08-18 09:01:00.437 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_normalEnergySaving_active
... 6 more
2023-08-18 09:01:00.443 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_normalEnergySaving_demand
... 6 more
2023-08-18 09:01:00.449 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_normalEnergySaving_reason
... 6 more
2023-08-18 09:01:00.455 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_normal_active
... 6 more
2023-08-18 09:01:00.460 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_normal_temperature
... 6 more
2023-08-18 09:01:00.466 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_reduced
... 6 more
2023-08-18 09:01:00.471 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_reducedEnergySaving_active
... 6 more
2023-08-18 09:01:00.477 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_reducedEnergySaving_demand
... 6 more
2023-08-18 09:01:00.490 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_reducedEnergySaving_reason
... 6 more
2023-08-18 09:01:00.495 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_reduced_active
... 6 more
2023-08-18 09:01:00.502 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_reduced_temperature
... 6 more
2023-08-18 09:01:00.509 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_standby_active
... 6 more
2023-08-18 09:01:00.515 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_operating_programs_summerEco_active
... 6 more
2023-08-18 09:01:00.520 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_sensors_temperature_supply
... 6 more
2023-08-18 09:01:00.526 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_sensors_temperature_supply_status
... 6 more
2023-08-18 09:01:00.531 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_0_zone_mode_active
... 6 more
2023-08-18 09:01:00.536 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_heating_curve_shift
... 6 more
2023-08-18 09:01:00.546 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_heating_curve_slope
... 6 more
2023-08-18 09:01:00.554 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_comfort
... 6 more
2023-08-18 09:01:00.560 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_comfort_active
... 6 more
2023-08-18 09:01:00.567 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_comfort_temperature
... 6 more
2023-08-18 09:01:00.574 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_normal
... 6 more
2023-08-18 09:01:00.580 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_normal_active
... 6 more
2023-08-18 09:01:00.587 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_normal_temperature
... 6 more
2023-08-18 09:01:00.595 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_reduced
... 6 more
2023-08-18 09:01:00.604 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_reduced_active
... 6 more
2023-08-18 09:01:00.612 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_reduced_temperature
... 6 more
2023-08-18 09:01:00.619 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_standby_active
... 6 more
2023-08-18 09:01:00.626 [WARN ] [re.internal.VicareDeviceThingHandler] - Unexpected exception handling command REFRESH for channel vicare:heating:varazze:caldaia24kW:heating_circuits_1_operating_programs_summerEco_active
... 6 more
