I’m able to conditionaly hide/show regular elements like Texts, Setpoint etc.
but when I try that on Webview it’s not working as well as on section (or how it’s called)
this works: (VisibilityHelper is by rules operated switch)
Text label="Automatic Schedule" visibility=[VisibilityHelper=="ON"]
but this is not
Text label="Automatic Schedule" visibility=[VisibilityHelper=="ON"] {
Text label="test"
is this correct behaviour or bug?
in the documentation is mentioned that All sitemap elements shoul be configured hidden …
as well this is not working with Item type Webview
Not sure if these two are somehow special or smthing
This construction seems to work for me, in BasicUI and ClassicUI. What behaviour do you see?
If you are looking at the “sub-page” when the visibility controller changes, that doesn’t close. That might be expected, because the visibility control is about the “parent” widget, not the sub-page navigation. It is arguable either way.
Adding visibility= to the widget(s) on the sub-page is no help of course, you’re just left with a blank page
I’ve no webview to play with, what happens with that? As I recall, they can be a bit flaky anyway in some UI/browser combos.
wbehaviour with webview and section is for me same, means they keeps hidden even when helper is ON
eg. when hiding single item it is hiding/showing as helper switching on/off, but when there is something under the item in brackets whole section just stay hidden, same with webview.
which build ur running? am on 2.5M2
logs are clear so not sure where to start debugging
Okay, the brackety-subpage part works fine for me in OH 2.4, BasicUI. I didn’t play with frames. The notable difference in my test was I was using some other button on the sitemap to control.
This might be more about getting the state update to the UI than the hide/show mechanism. This part is often tricky with the sitemap UIs.
Here’s an experiment, display the state of your “helper” / controlling Item somewhere with a Text in your sitemap. I suspect an update to a never displayed Item may be missed.
If that works, I suppose a bizarre workaround might be to “display” the control in a Text widget that has its own visibility set by some untrue condition as always off.
