First of all, thanks for 1.0.2 — hover on items inside .js files is exactly what I was missing, and it works nicely.
There is one side effect. Since installing 1.0.2 I get an error in the language server output channel every time I touch an openHAB configuration file. Adding a single space is enough to trigger it, and it repeats on every keystroke.
[Error - 9:27:41 AM] Notification handler 'textDocument/didOpen' failed with message: Cannot read properties of undefined (reading 'create')
[Error - 9:27:41 AM] Notification handler 'textDocument/didChange' failed with message: Cannot read properties of undefined (reading 'update')
Clearly tied to the version
- 1.0.2 installed: the errors appear.
- Back to 1.0.0: the errors are gone.
When it happens
- On every openHAB file:
.items,.things,.rules,.sitemap,.persist.didOpenfires once when the file is opened,didChangeon every edit. - Not on
.jsfiles, which is the odd part given that JS support is what 1.0.2 adds. - Hover, validation and completion still appear to work, so this is noise rather than a broken feature — but the server’s document mirror is clearly not being updated, and I don’t know what silently depends on that.
Setup
- openHAB 5.2.0 in Docker on Ubuntu, config on a shared folder
- VS Code 1.140.0, openHAB extension 1.0.2
- Remote language server enabled:
"openhab.useRestApi": true,
"openhab.connection.host": "192.168.100.52",
"openhab.connection.port": 8080,
"openhab.languageserver.remoteEnabled": true,
"openhab.languageserver.remotePort": 5007
Likely cause
The message is a JavaScript TypeError, so it comes from the JS side rather than from the Xtext server. Both messages match the signature of a TextDocuments instance created without the document factory. Since vscode-languageserver 6, the constructor requires it; without it the internal configuration is undefined, and didOpen fails on .create() while didChange fails on .update() — exactly the pair above.
// fails on didOpen/didChange with vscode-languageserver >= 6
const documents = new TextDocuments();
// expected
const { TextDocument } = require('vscode-languageserver-textdocument');
const documents = new TextDocuments(TextDocument);
Would you be able to look at this? I’d rather stay on 1.0.2 for the JS hover, so I’m happy to supply a verbose trace or test a patched build.
