I have a screen that rotates between different tabs, one of them security camera’s another grafana stats from the house
I would like to add another tab page where I can see the last logs from openhab.
The idea being that it’s good from time to time to see the logs even if I’m not working on it, just t be sure I see possible errors
I’m now logging on in a terminal window to look at the logs (which is perfect for working on it and debugging)
What would be a good solution to see these logs from a browser?
Take a look at the openhab log viewer webapp. You can activate it via openhabian-config (Optional Components - Log Viewer). I think it does pretty much exactly what you want.
