does the Vitotronic Binding support the Vitoconnect 100 Box? I didn’t get it it running.
If not are there plans to do so?
Thanks and Regards,
Alex
Thanks and Regards,
Alex
any update on this one?
I’m also intrested in using Vitoconnect 100 with openahb.
Thanks!
may someone get this to work in Openhab?
Hi all,
I’m also interested in using this VitoConnect 100 with OpenHAB2.
Any news on this?
Tx!
Regards
I found something on the FHEM Forum.
A french user (“thetrueavatar”) has posted his solution for the use of the Viesmann API by means of a phpscript.
He posted all on Github.
So fast I have tested it with some readings (outside temperature etc.) , it should work for settings also.
