Maybe you have an idea how I can simplify my rule.
I want to bring my shutters to a certain height by voice command (10, 20, 30, …, 100). So far my rule looks like this:
rule "Voice"
Item VoiceCommand received command
var String command = receivedCommand.toString.toLowerCase
logInfo("Voice.Rec","VoiceCommand received "+command)
if (command.contains("10")&&command.contains("rollo"))
if (command.contains("1")) {
S1.sendCommand(10)
else if (command.contains("2")) {
S2.sendCommand(10)
else if (command.contains("3")) {
S3.sendCommand(10)
else if (command.contains("4")) {
S4.sendCommand(10)
else if (command.contains("5")) {
S5.sendCommand(10)
else if (command.contains("küche")&&command.contains("tür")) {
S6.sendCommand(10)
else if (command.contains("küche")&&command.contains("fenster")) {
S7.sendCommand(10)
else if (command.contains("wc")) {
GF_Toilet_Shutter.sendCommand(10)
else if (command.contains("htr")) {
GF_LaundryRoom_Shutter.sendCommand(10)
else if (command.contains("bad")) {
FF_Bathroom_Shutter.sendCommand(10)
else if (command.contains("schlafzimmer")) {
FF_Bedroom_Shutter.sendCommand(10)
else if (command.contains("lilia")) {
FF_KidsRoom_Shutter.sendCommand(10)
else if (command.contains("johannes")) {
FF_GuestRoom_Shutter.sendCommand(10)
This works so far. Unfortunately I would have to do it nine more times. That somehow doesn’t seem very effective to me.
switch(expression) {
case x:
// code block
break;
case y:
// code block
break;
default:
// code block
So
rule "Voice"
switch (command) {
case '1' : S1.sendCommand(10)
case '2' : S2.sendCommand(10)
I do not have rollershutters.
When I compare it to setup for lightning I would have assumed that it is possible to do this without setting up a specific rule.
For lightning setup like it is required for loudness of a receiver e.g.
