Voice RSS TTS pronouncing the thousand numbers correctly
How do I get Voice RSS TTS to pronounce the thousand numbers correctly instead of calling the numbers individually? It is working for the hundreds.
Could it be that SSML is required to use pronounce it that way:
OK, I found it. The number needs a thousands separator, also for German, although uncommon there. Can be tested here: Voice RSS - Text-to-speech (TTS) live demo with Voice RSS API
