Hi - i’m trying to find out why this rule is not working:
Basically is a voice rule where i want to do three different actions for three different voice commands.
If i use a single condition, works - with two or more… no way. I can’t understand where i’m wrong.
rule “Accendi la luce dello studio”
Item VoiceCommand received command
var String = null
var String command = VoiceCommand.state.toString.toLowerCase
logInfo(“Voice.Rec”,“VoiceCommand received”+command)
if (command.contains("Accendi la luce dello studio"))
{sendCommand(Luce_studio, ON)}
else
if (command.contains("Spegni la luce dello studio"))
{sendCommand(Luce_studio, OFF)}
else
if (command.contains("Accendi la luce del corridoio"))
{sendCommand(interruttori_corridoio, ON)}
I’m currently having troubles executing my Voicecommand rules, after upgrade to OH2.3.0 Build#1232.
rule "Voice control"
logInfo("Voice.Rec","VoiceCommand received "+command)
if
(command.contains("tv"))
sendCommand(Loxone_AllMediaONOFF, "ON")
log:
2018-03-20 20:16:26.998 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command tv
2018-03-20 20:16:31.413 [INFO ] [pse.smarthome.model.script.Voice.Rec] - VoiceCommand received null
I may be totally wrong here, but I am reading quite a few posts where a rule gets triggered faster than the state of an item gets updated (apparently connected to the concept that OH2 is based on an event bus); which, if true and applicable to your case, may mean that your item state has not been updated yet when your rule triggers. An easy way to find out is to add sleep statement:
Thread::sleep(50)
this would add a 50ms second pause to allow your system to catch up…
just a thought…(and no guarantee that I am even on the right track)
It could be that the state has not changed yet. It takes a few ms.
var String command = receivedCommand.toString.toLowerCase
logInfo("Voice.Rec","VoiceCommand received " + command)
if (command.contains("tv")) {
Loxone_AllMediaONOFF.sendCommand(ON)
@lipp_markus you are in the right track but sleeping for 50ms is a bit hacky.
Use implicit variables if you can. In this case receivedCommand is perfect.
