Hi
I have a strange issue with the Frontier Silicon binding. I have a (pretty old) Dual radio that I connected to via the binding. In general, everything works. However, the volume control somehow changes the volume on its own.
Specifically, if I set a certain volume, e.g. 40%, the volume briefly rises to this value, but then gradually goes back to a value of about 20%. First, I thought, that can’t be. But it is very reproducible. It only happens, when using the binding in openhab. There is no such effect, when using the UNDOK app and neither when directly calling the API via webbrowser.
I did a short tcpdump to see, if there are indeed commands been send to the radio, and yes, they are!
19:26:33.500536 IP swarm-worker1.mbhome.41158 > 172.17.4.26.http: Flags [P.], seq 1:166, ack 1, win 502, length 165: HTTP: GET /fsapi/SET/netRemote.sys.audio.volume?pin=1234&sid=2038482803&value=10 HTTP/1.1
19:26:34.652128 IP swarm-worker1.mbhome.41164 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:34.666767 IP swarm-worker1.mbhome.41166 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:35.703727 IP swarm-worker1.mbhome.41174 > 172.17.4.26.http: Flags [P.], seq 1:165, ack 1, win 502, length 164: HTTP: GET /fsapi/SET/netRemote.sys.audio.volume?pin=1234&sid=2038482803&value=9 HTTP/1.1
19:26:36.744984 IP swarm-worker1.mbhome.41184 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:36.758551 IP swarm-worker1.mbhome.41186 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:37.905588 IP swarm-worker1.mbhome.41194 > 172.17.4.26.http: Flags [P.], seq 1:165, ack 1, win 502, length 164: HTTP: GET /fsapi/SET/netRemote.sys.audio.volume?pin=1234&sid=2038482803&value=8 HTTP/1.1
19:26:38.945726 IP swarm-worker1.mbhome.41206 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:38.959792 IP swarm-worker1.mbhome.41208 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:40.114890 IP swarm-worker1.mbhome.41220 > 172.17.4.26.http: Flags [P.], seq 1:165, ack 1, win 502, length 164: HTTP: GET /fsapi/SET/netRemote.sys.audio.volume?pin=1234&sid=2038482803&value=7 HTTP/1.1
19:26:41.159703 IP swarm-worker1.mbhome.41230 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
19:26:41.173256 IP swarm-worker1.mbhome.41232 > 172.17.4.26.http: Flags [P.], seq 1:157, ack 1, win 502, length 156: HTTP: GET /fsapi/GET/netRemote.sys.audio.volume?pin=1234&sid=2038482803 HTTP/1.1
This dump show that the initial command raises the volume to 10 (out of 32, I believe), but then there are following commands that slowly reduce the volume back to 7 (first 9, then 8, then 7).
I have no idea, why that is happening. Can anyone enlighten me?
Michael
