Ok, this means your trips get updated but not the vehicle status :-/
Removed Things
Removed VOC binding
Removed items
Stopped OH
Cleaned cache
Started OH
Waited OH to settle
Re-installed VOC binding
Created Things
Put items in place
Result:2020-05-14 18:13:53.511 [INFO ] [l.internal.action.VolvoOnCallActions] - Volvo On Call actions service instanciated 2020-05-14 18:13:53.559 [TRACE] [call.internal.handler.VehicleHandler] - Initializing the Volvo On Call handler for volvooncall:vehicle:xxx 2020-05-14 18:13:54.992 [DEBUG] [call.internal.handler.VehicleHandler] - Trips discovered : 1 2020-05-14 18:13:54.995 [DEBUG] [call.internal.handler.VehicleHandler] - Trip found 2020-05-10T15:56:27.000+0200 2020-05-14 18:13:55.059 [DEBUG] [call.internal.handler.VehicleHandler] - Trips discovered : 1 2020-05-14 18:13:55.062 [DEBUG] [call.internal.handler.VehicleHandler] - Trip found 2020-05-10T15:56:27.000+0200 2020-05-14 18:13:55.379 [DEBUG] [call.internal.handler.VehicleHandler] - Trips discovered : 1 2020-05-14 18:13:55.381 [DEBUG] [call.internal.handler.VehicleHandler] - Trip found 2020-05-10T15:56:27.000+0200 2020-05-14 18:13:55.413 [DEBUG] [call.internal.handler.VehicleHandler] - Trips discovered : 1 2020-05-14 18:13:55.415 [DEBUG] [call.internal.handler.VehicleHandler] - Trip found 2020-05-10T15:56:27.000+0200 2020-05-14 18:13:55.615 [DEBUG] [call.internal.handler.VehicleHandler] - Trips discovered : 1
Why is this updated so often?
I will try another restart of OH
EDIT: Still no update on the items
Hello, how do I exactly install that new PR? Can anybody give me a short hint on that, please? Do I have just to uninstall and then to re-install the VOC binding and thatās it?
Thanks.
Just remove the actual one using PaperUI and copy the newer downloaded .jar file into: /usr/share/openhab2/addons
Thanks for the hint. Where can I download the latest version of the Binding?
I have the latest snapshot running as well - it has fixed most issues (items are updating again), however I am also having ācar lockedā return a NULL valueā¦
Thatās weird, that my items are not updated.
I donāt have a clue anymore what might be wrong.
Any suggestion how I could continue to troubleshoot?
I also tried older VOC bindings back to 2.5.0
With 2.5.0 I get at least:
2020-05-15 09:30:02.762 [vent.ItemStateChangedEvent] - CarHeater changed from UNDEF to NULL
2020-05-15 09:30:02.775 [vent.ItemStateChangedEvent] - CarBrakeFl changed from to NULL
Please see my post 49 above
@NCO : could you please try this version and let me know if status informations are updated ?
To answer
=> When a new vehicle āthingā is created, the binding rewinds all past trips provided by the API until the very last one that is then stored in the vehicle properties with the ālastTripIdā label.
Thanks - I will try your proposed version right away.
By the way this pops up, when using 2.5.0:
2020-05-15 09:40:18.488 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler VehicleHandler of thing volvooncall:vehicle:YV1DZA8CDH2035799 tried accessing its bridge although the handler was already disposed.
2020-05-15 09:40:18.490 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler VehicleHandler tried updating the thing status although the handler was already disposed.
So, 2.5.0 seems to show āmore lifeā.
I have seen this message a few months ago, but did not see any negative impact.
Will report about latest version soon
This leads my vehicle to go offline:
2020-05-15 09:50:26.552 [hingStatusInfoChangedEvent] - 'volvooncall:vehicle:xxx' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-05-15 09:50:26.669 [hingStatusInfoChangedEvent] - 'volvooncall:vehicle:xxx' changed from INITIALIZING to ONLINE
2020-05-15 09:50:26.828 [hingStatusInfoChangedEvent] - 'volvooncall:vehicle:xxx' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): UnknownError
EDIT:
I will restart OH to make sureā¦
Donāt loose to much time testing this version. This error was expected (apparently VoC services have changed the headers they expect and I corrected that in the last merged PR), leading to status not being updated while trip were fine.
Maybe you could send me the json answer made by the rest service if you can extract it ?
Thanks a lot for your strong support!
Could you please tell me how to get the json response
I donāt know if with molobrackos script youāre able to have some kind of āverboseā mode or else Iāll give you a special version with more debug log.
Ah, alright.
I will send you the beginning of the response with a PM (just in case I missed to delete personal data
I hope thatās sufficient.
Hopefully found the problem, PR created
OK, thanks a lot. Iām currently on OpenHAB 2.5.4 can I use the binding as it is labeled with 2.5.5?
Yes, thatās usually not a problem - only if major changes have taken place between the releases.
Wanted to download the binding yet but cannot find a download link. Only the remark āNo path found (externally resolved or deleted/overwrittenā is shown. Or am I on the wrong position there?
