- Platform information:
- Hardware: RPi 2
- OS: Raspbian Stretch
- Java Runtime Environment: Zulu8
- openHAB version: 2.2 stable
I managed to connect my remote Raspbian runnung OH2 directly with my FritzBox at home using vpnc. For now, everything works:
- I can access my home network from remote
- I can access my remote Pi from home
- the PI can use internet Access
What’s a bit strange in my eyes, if I login to my remote Pi via its remote IP, I nevertheless get this login screen:
[22:12:02] openhabian@openHAB2-huette:~$
Using username "openhabian".
openhabian@192.168.90.10's password:
Linux openHAB2-huette 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Feb 16 22:11:10 2018 from 192.168.90.35
################# openHAB2-huette #############################################
## Ip = 192.168.187.201
## Release = Raspbian GNU/Linux 9 (stretch)
## Kernel = Linux 4.9.59-v7+
## Platform = Raspberry Pi 2 Model B Rev 1.1
## Uptime = 27 day(s). 4:3:4
## CPU Usage = 0.25 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.18, 5m: 0.15, 15m: 0.08
## Memory = Free: 0.10GB (10%), Used: 0.85GB (90%), Total: 0.95GB
## Swap = Free: 0.08GB (90%), Used: 0.00GB (10%), Total: 0.09GB
## Root = Free: 53.31GB (96%), Used: 2.12GB (4%), Total: 58.43GB
## Updates = 0 apt updates available.
## Sessions = 2 sessions
## Processes = 138 running processes of 32768 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.2.0-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at http://docs.openhab.org/installation/openhabian.html
The openHAB dashboard can be reached at http://openHAB2-huette:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
192.168.90.x is the subnet of my remote Network
192.168.187.x is the subnet of my home Network
So, why is the IP-address shown here the one of my home-VPN IP-Address?
[22:14:56] openhabian@openHAB2-huette:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.90.10 netmask 255.255.255.0 broadcast 192.168.90.255
inet6 fd80:5973:1834::a00 prefixlen 128 scopeid 0x0<global>
inet6 fe40::8a15:312d:eaf0:2afe prefixlen 64 scopeid 0x20<link>
inet6 fd80:5853:1330:0:9559:5244:a2fb:3edf prefixlen 64 scopeid 0x0<global>
ether b8:27:eb:02:30:48 txqueuelen 1000 (Ethernet)
RX packets 1208310 bytes 370548335 (353.3 MiB)
RX errors 0 dropped 34 overruns 0 frame 0
TX packets 667813 bytes 108400553 (103.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Lokale Schleife)
RX packets 24392 bytes 2231961 (2.1 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 24392 bytes 2231961 (2.1 MiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1412
inet 192.168.187.203 netmask 255.255.255.255 destination 192.168.187.203
inet6 fe80::2766:a66f:efca:fa47 prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 500 (UNSPEC)
RX packets 104 bytes 13488 (13.1 KiB)
TX packets 173 bytes 64807 (63.2 KiB)
Is this something, I have to be concerned about? at present all seems to work as it should, but I’m just curious, why there’s not the remote-IP is shown here…
VPNC is configured accordingly:
/etc/vpnc/fritzbox.conf
IPSec gateway xxxx.myfritz.net
IPSec ID yyy
IPSec secret xyz
IKE Authmode psk
Xauth username yyy
Xauth password zzz
local port 0
DPD idle timeout (our side) 0
I start it with sudo vpnc fritzbox.conf
