Dear openHAB-community,
during writing my rules and other stuff in VS Code I continously get an exception in the output panel of VS Code. openHAB is running normally, the created files are loaded into openHAB as expected.
I just don’t get the hover experience in openHAB.
Problem
In VS Code I don’t get the hover experience when I put my cursor above an item.
System topologie
- openHAB as Docker-compose container
- Docker-compose running on Debian
- Debian as Linux Subsystem for Windows
- All configuration files are mounted as usual
- UI is accessible on the local Windows machine
- The VS Code extension can properly load all items and things from openHAB - so the connection is working finde
- the language server port is 5007
- the UI port is 8083 due to an other program using 8080 on the windows localhost
