Hi all,
Today I tried VS Code extension first time, and it works great and I wish I knew the tool earlier The only issue I have is when I Cmd+Click a method, I receive the following error in both VS Code and openhab.log. I run OH version 3.3.0 and VS code extension 1.0.0. Any suggestion how to fix it? Thank you in advance!
[Error - 10:14:46 AM] Request textDocument/definition failed.
Message: Internal error.
Code: -32603
java.util.concurrent.CompletionException: java.lang.RuntimeException: Cannot create a resource for ‘java:/Objects/org.openhab.core.library.types.PercentType’; a registered resource factory is needed
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:331)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:346)
at java.base/java.util.concurrent.CompletableFuture$UniAccept.tryFire(CompletableFuture.java:704)
at java.base/java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:506)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:2088)
at org.eclipse.xtext.ide.server.concurrent.AbstractRequest.logAndCompleteExceptionally(AbstractRequest.java:73)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:69)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
