I am running OH 2.x on my local windows box. I got the common “Cannot connect to Debuggee” error, aka “Failed to attach to remote debuggee VM … Connection refused.” in VS Code. Sometimes the debug-task starts without an error message, but I am not able to hit the breakpoints, that VS Code is stopping at them and showing me the common views like variables and jump-options.
Anyway, is there a possibility to use an external debugger or is there some progress on using IntelliJ for OH development, i.e. an official guide in the OH docs?
I am really happy, that I can build and deploy my addons now and I am eclipse independant. Writing some OH-related Java code works with VS Code as well, but now I need to make sure, that I am able to debug efficiently - writing log-statements is a little bit “Seventies”, isn’t it?
When you start OH with the debug option - the console should show a line like: Listening for transport dt_socket at address: xxxx (where xxxx is the port - likely 5005)
Do you see that and is it 5005? I’d check to see if something else on the system is listening on that port as well..
