VsCode: No such compiler 'eclipse'
  • Platform information:
    • Hardware: x64
    • OS: Windows 11
    • Java Runtime Environment: OpenJDK Runtime Environment Zulu21.42+19-CA
    • openHAB version: 5.2.0
  • Issue of the topic: The compilation on VsCode stops working.
    After a merge this morning, I’m unable to compile any binding.
    The last working compilation was on 23/01/2026.
    [ERROR] Compiler 'eclipse' could not be instantiated or injected properly. If you spelled the compiler ID correctly and all necessary dependencies are on the classpath, then next you can try running the build with -Dsisu.debug, looking for exceptions. TypeNotPresentException caused by UnsupportedClassVersionError might indicate, that the compiler needs a more recent Java runtime. IllegalArgumentException in ClassReader.<init> might mean, that you need to upgrade Maven.
    [DEBUG] Adding D:\Development\openhab-addons\bundles\org.openhab.binding.velbus\target\generated-sources\annotations to the project compile source roots but NOT the actual compile source roots:
      D:\Development\openhab-addons\bundles\org.openhab.binding.velbus\src\main\java
    [INFO] ------------------------------------------------------------------------
    [INFO] BUILD FAILURE
    [INFO] Total time:  6.921 s
    [INFO] Finished at: 2026-01-27T10:31:11+01:00
    [ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.14.1:compile (default-compile) on project org.openhab.binding.velbus: No such compiler 'eclipse'. -> [Help 1]
    org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.14.1:compile (default-compile) on project org.openhab.binding.velbus: No such compiler 'eclipse'.
        at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute2 (MojoExecutor.java:375)
        at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute (MojoExecutor.java:351)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:171)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:163)
        at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
        at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
        at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
        at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
        at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:294)
        at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
        at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
        at org.apache.maven.cli.MavenCli.execute (MavenCli.java:960)
        at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:293)
        at org.apache.maven.cli.MavenCli.main (MavenCli.java:196)
        at jdk.internal.reflect.DirectMethodHandleAccessor.invoke (DirectMethodHandleAccessor.java:103)
        at java.lang.reflect.Method.invoke (Method.java:580)
        at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
        at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
        at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
        at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
    Caused by: org.apache.maven.plugin.MojoExecutionException: No such compiler 'eclipse'.
        at org.apache.maven.plugin.compiler.AbstractCompilerMojo.executeReal (AbstractCompilerMojo.java:752)
        at org.apache.maven.plugin.compiler.AbstractCompilerMojo.execute (AbstractCompilerMojo.java:708)
        at org.apache.maven.plugin.compiler.CompilerMojo.execute (CompilerMojo.java:235)
        at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
        at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute2 (MojoExecutor.java:370)
    Caused by: org.codehaus.plexus.compiler.manager.NoSuchCompilerException: No such compiler 'eclipse'
        at org.codehaus.plexus.compiler.manager.DefaultCompilerManager.getCompiler (DefaultCompilerManager.java:64)
        at org.apache.maven.plugin.compiler.AbstractCompilerMojo.executeReal (AbstractCompilerMojo.java:750)
    [ERROR]
    [ERROR]
    [ERROR] For more information about the errors and possible solutions, please read the following articles:
    [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
The error is introduced by the commit 9039ea0 (PR #20135).
VsCode compilation error since commit 9039ea0 · Issue #20154 · openhab/openhab-addons
Revert back plexus-compiler-eclipse to version 2.12.1 is a workaround to the problem.
The final solution was to update Maven to the last version (currently 3.9.12)
