Hi. Is WOL still working with openhab2?
I’ve enabled legacy mode, installed the binding and configured a widget in the Habpanel.
With the following entry in items:
Switch DesktopPC “Desktop PC Computer” (Status, Network) { wol=“192.168.0.255#94:de:80:7d:27:95” }
No joy when toggling the switch on the panel. It doesn’t wake the PC. All works fine with WOL using other apps. Any advice?
Many thanks for this Ganesh
I tried replacing the 255 with a 0. Did not work for me.
I don’t have an asus motherboard, but wake on lan is enabled and works with other wol apps on the lan network.
I setup the v2.1 binding and it works great, personally had to set it up for direct IP, but that might be because I have DHCP setup giving IP Addresses.
Further to this, I was wondering if we could have the status of the PC check if it can receive a ping? and if so, state the PC is on, if not, state it’s off because at the moment the status says “ready” or “ping sent” which is handy to know you sent the ping, but after that, you don’t know if the PC actually turned on…
