Waking device to complete discovery results in node going offline (COMMUNICATION_ERROR)
I’m trying to include an Aeotec TriSensor (ZWA005) and after I do the initial inclusion in HABmin, I wake the device to start the process of getting it identified by the binding but doing this results in a communication error and the device is marked as offline.
The step that fails appears to be the APP_VERSION part. Trying to wake the device again will have the device appear online again, but eventually produces the same result and is marked offline again.
I have the device right beside the USB controller.
I’ve attached a log of the entire inclusion and wake process:
zwa005_error.txt (160.5 KB)
I’ve tried excluding and re-including the device a few times now with the same result.
When restarting OpenHAB, the device becomes successfully identified as the ZWA005, but doesn’t seem to work after that and the information on the Attributes pane appears incomplete when compared to another ZWA005 I have included in the past. The device also suddenly changes from using security to not using security after the restart.
Any thoughts about what else I should try or what might be happening?
Some how after excluding and including it several times, it seemed to get past the APP_VERSION stage, but now seems to be stuck in the VERSION stage in the same way.
zwa005_error3.txt (74.6 KB)
Well somehow it’s working now after excluding it and re-including it multiple times. Finally, I restarted OpenHAB and from a different room of the house (not right next to the controller), I kept on pushing the action button.
Based on the manual, to wake the device, I’m supposed to press and hold the button for 2 seconds. However doing this, even though the LED indicator on the device responds correctly (turns on red to indicate it is awake), nothing appears in the binding debug logs. The only way I could get some response on the binding side was to press the button once, which according to the manual sends an NIF.
The behaviour I was seeing before sounded similar to this: NIF being used as wakeup is not reliable · Issue #127 · openhab/org.openhab.binding.zwave · GitHub
The device would “wake”, then OpenHAB would try to communicate with it, but it seems like the device isn’t listening and never responds. When I saw in the logs that the binding was starting to complain about retries, I would press the action button again, and that would at least prevent it from going to the offline state. Eventually after continually pressing the button (not according to how the manual seems to suggest the wakes should work), the binding managed to get all the information from the device and it seems to be connected (at least, reporting the motion alarm now).
I’m not sure why this seems so flaky for me - does anyone have any tips or suggestions about getting more consistent results with the inclusion process? With the first TriSensor I included, I didn’t seem to have any of these problems at all and it just worked without a hitch.
I did send a support request to Aeotec and will see if they have any suggestions (I’m wondering now if it’s a problem with the device or a wireless communication issue).
