I wrote a small MQTT wrapper which allows you an easy integration into Openhab (at least if you use MQTT). I could use the Linux Input binding, however I guess its not so easy to recognize long press or maybe double klick (not yet implemented).
Don’t worry, after playing with this all day, I wiped the system and tried again and now all OK. I think this was an error in how I installed nodejs which meant that it wasn’t linked to /usr/bin. Now works all OK, and for others, if you have authentication on your MQTT broker, just change the MQTT line in config.yaml to be mqtt://username:password@brokerIP.
