I see in my logs sometimes warning from the nal.model.GenericResponseTransformer: 2023-02-13 21:59:02.357 [WARN ] [nal.model.GenericResponseTransformer] - caught exception while trying to update channel state#latestPulse with value '2023-02-13T20:57:12.000Z'. Exception: Text '2023-02-13T20:57:12.000Z' could not be parsed at index 19
Which device or script sends this warning?
How can I remove or fix it?
Do you use the easee binding ? Then it is most probably cause by that binding as it seems to be the only binding that shows GenericResponseTransformer in its soource code.
Increase that bindings loglevel to debug or trace. I would expect to the see data being processed then in the logging. Watch for normal traffic and traffic that raises the error message there should be a difference. I have no idea what this would mean about amount of data that will be logged. So you may be need to be carefull that the log space will not run out of space.
Are date/timestamps always sent in the same time format …?
