When creating a Skeleton i receive some Warnings
[INFO] Scanning for projects...
Downloading from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/openhab/pom-tycho/2.5.0-SNAPSHOT/maven-metadata.xml
Downloading from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/openhab/pom-tycho/2.5.0-SNAPSHOT/maven-metadata.xml
Downloaded from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/openhab/pom-tycho/2.5.0-SNAPSHOT/maven-metadata.xml (599 B at 376 B/s)
[WARNING] Could not transfer metadata org.openhab:pom-tycho:2.5.0-SNAPSHOT/maven-metadata.xml from/to p2-openhab-deps-repo (https://dl.bintray.com/openhab/p2/openhab-deps-repo/${ohdr.version}): Cannot access https://dl.bintray.com/openhab/p2/openhab-deps-repo/${ohdr.version} with type p2 using the available connector factories: BasicRepositoryConnectorFactory
Downloading from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/openhab/pom/2.5.0-SNAPSHOT/maven-metadata.xml
Downloading from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/openhab/pom/2.5.0-SNAPSHOT/maven-metadata.xml
Downloaded from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/openhab/pom/2.5.0-SNAPSHOT/maven-metadata.xml (593 B at 1.6 kB/s)
[WARNING] Could not transfer metadata org.openhab:pom:2.5.0-SNAPSHOT/maven-metadata.xml from/to p2-openhab-deps-repo (https://dl.bintray.com/openhab/p2/openhab-deps-repo/${ohdr.version}): Cannot access https://dl.bintray.com/openhab/p2/openhab-deps-repo/${ohdr.version} with type p2 using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] The POM for org.openhab.tools.sat:sat-plugin:jar:{sat.version} is missing, no dependency information available
[WARNING] Failed to retrieve plugin descriptor for org.openhab.tools.sat:sat-plugin:{sat.version}: Plugin org.openhab.tools.sat:sat-plugin:{sat.version} or one of its dependencies could not be resolved: Failure to find org.openhab.tools.sat:sat-plugin:jar:{sat.version} in https://jcenter.bintray.com/ was cached in the local repository, resolution will not be reattempted until the update interval of jcenter has elapsed or updates are forced
[INFO]
[INFO] ----------------------< org.openhab.binding:pom >-----------------------
[INFO] Building openHAB Bindings 2.5.0-SNAPSHOT
[INFO] --------------------------------[ pom ]---------------------------------
[INFO]
[INFO] >>> maven-archetype-plugin:3.0.1:generate (default-cli) > generate-sources @ pom >>>
[INFO]
[INFO] --- directory-maven-plugin:0.2:highest-basedir (directories) @ pom ---
[INFO] Highest basedir set to: C:\Users\micha\Eclipse\openhab2-master\git\openhab2-addons
[INFO]
[INFO] <<< maven-archetype-plugin:3.0.1:generate (default-cli) < generate-sources @ pom <<<
[INFO]
[INFO]
[INFO] --- maven-archetype-plugin:3.0.1:generate (default-cli) @ pom ---
[INFO] Generating project in Interactive mode
[INFO] Archetype repository not defined. Using the one from [org.eclipse.smarthome.archetype:org.eclipse.smarthome.archetype.binding:0.7.0-SNAPSHOT -> https://repo.eclipse.org/content/repositories/smarthome-snapshots] found in catalog remote
Downloading from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/archetype/org.eclipse.smarthome.archetype.binding/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/archetype/org.eclipse.smarthome.archetype.binding/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/archetype/org.eclipse.smarthome.archetype.binding/0.11.0-SNAPSHOT/maven-metadata.xml
Downloaded from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/archetype/org.eclipse.smarthome.archetype.binding/0.11.0-SNAPSHOT/maven-metadata.xml (823 B at 1.9 kB/s)
Downloaded from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/archetype/org.eclipse.smarthome.archetype.binding/0.11.0-SNAPSHOT/maven-metadata.xml (823 B at 1.5 kB/s)
Downloaded from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/archetype/org.eclipse.smarthome.archetype.binding/0.11.0-SNAPSHOT/maven-metadata.xml (823 B at 925 B/s)
Downloading from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/archetype/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/tools/archetype/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/archetype/0.11.0-SNAPSHOT/maven-metadata.xml
Downloaded from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/archetype/0.11.0-SNAPSHOT/maven-metadata.xml (615 B at 1.8 kB/s)
Downloaded from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/archetype/0.11.0-SNAPSHOT/maven-metadata.xml (615 B at 1.7 kB/s)
Downloaded from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/tools/archetype/0.11.0-SNAPSHOT/maven-metadata.xml (615 B at 1.4 kB/s)
Downloading from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/tools/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/0.11.0-SNAPSHOT/maven-metadata.xml
Downloaded from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/tools/0.11.0-SNAPSHOT/maven-metadata.xml (605 B at 582 B/s)
Downloaded from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/0.11.0-SNAPSHOT/maven-metadata.xml (605 B at 440 B/s)
Downloaded from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/tools/0.11.0-SNAPSHOT/maven-metadata.xml (605 B at 432 B/s)
Downloading from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/smarthome/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/smarthome/0.11.0-SNAPSHOT/maven-metadata.xml
Downloading from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/smarthome/0.11.0-SNAPSHOT/maven-metadata.xml
Downloaded from openhab-artifactory-snapshot: https://openhab.jfrog.io/openhab/libs-snapshot/org/eclipse/smarthome/smarthome/0.11.0-SNAPSHOT/maven-metadata.xml (609 B at 1.2 kB/s)
Downloaded from org.eclipse.smarthome.archetype.binding-repo: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/smarthome/0.11.0-SNAPSHOT/maven-metadata.xml (609 B at 1.2 kB/s)
Downloaded from archetype: https://repo.eclipse.org/content/repositories/smarthome-snapshots/org/eclipse/smarthome/smarthome/0.11.0-SNAPSHOT/maven-metadata.xml (609 B at 1.1 kB/s)
[INFO] Using property: groupId = org.openhab.binding
[INFO] Using property: artifactId = org.openhab.binding.test
[INFO] Using property: version = 2.5.0-SNAPSHOT
[INFO] Using property: package = org.openhab.binding.test
[INFO] Using property: author = Michael Parment
[INFO] Using property: bindingId = test
[INFO] Using property: bindingIdCamelCase = test
[INFO] Using property: namespace = org.openhab
[INFO] Using property: startYear = 2014
[INFO] Using property: vendorName = openHAB
Confirm properties configuration:
groupId: org.openhab.binding
artifactId: org.openhab.binding.test
version: 2.5.0-SNAPSHOT
package: org.openhab.binding.test
author: Michael Parment
bindingId: test
bindingIdCamelCase: test
namespace: org.openhab
startYear: 2014
vendorName: openHAB
Y: : Y
[INFO] ----------------------------------------------------------------------------
[INFO] Using following parameters for creating project from Archetype: org.eclipse.smarthome.archetype.binding:0.11.0-SNAPSHOT
[INFO] Parameter: groupId, Value: org.openhab.binding
[INFO] Parameter: artifactId, Value: org.openhab.binding.test
[INFO] Parameter: version, Value: 2.5.0-SNAPSHOT
[INFO] Parameter: package, Value: org.openhab.binding.test
[INFO] Parameter: packageInPathFormat, Value: org/openhab/binding/test
[INFO] Parameter: bindingIdCamelCase, Value: test
[INFO] Parameter: vendorName, Value: openHAB
[INFO] Parameter: namespace, Value: org.openhab
[INFO] Parameter: author, Value: Michael Parment
[INFO] Parameter: startYear, Value: 2014
[INFO] Parameter: bindingId, Value: test
[INFO] Parent element not overwritten in C:\Users\micha\Eclipse\openhab2-master\git\openhab2-addons\addons\binding\org.openhab.binding.test\pom.xml
[WARNING] Don't override file C:\Users\micha\Eclipse\openhab2-master\git\openhab2-addons\addons\binding\org.openhab.binding.test\pom.xml
[INFO] Project created from Archetype in dir: C:\Users\micha\Eclipse\openhab2-master\git\openhab2-addons\addons\binding\org.openhab.binding.test
[INFO] BUILD SUCCESS
[INFO] Total time: 37.207 s
[INFO] Finished at: 2018-12-31T12:14:28+01:00
1 file(s) copied.
Can i ignore this?
/Mike
