I got update today, so everything is working. I can’t get it why it happened on Friday, but ok.
In the API call, I need to specify a From
and To
date.
From is current date + 1 day to keep on showing the waste collection of that day.
To is current date + 6 days.
When there is a weekly waste collection, this changes nicely. In your case it seems like not because of the 2 weekly collection.
New compiled JARs are available for OH2.5 and OH3.1. Please keep a copy of the original as I could not test it on OH3.1.
Change: added ***
as delimiter between waste collections.
Thanks, could you maybe make the To as a parameter, so I could change it for my case?
Done, available on Github. Both for OH2.5 and OH3.1
I have added the parameter daysToCheck
which defaults to 6 days. Minimal value is 1 day.
Have fun playing with it.
Thanks, I will give it a try
Hi @BeanzBE
I get the following error now:
2021-03-01 21:39:05.852 [INFO ] [um.internal.RecycleappBelgiumHandler] - Start fetching next waste collection...
2021-03-01 21:39:06.354 [INFO ] [um.internal.RecycleappBelgiumHandler] - java.lang.NullPointerException
2021-03-01 21:39:06.356 [INFO ] [um.internal.RecycleappBelgiumHandler] - Empty token
My thing config is:
Thing recycleappbelgium:Collection:Home "Waste@Home" [Zip="2950", Street="xxxx", HouseNumber="xx", refreshInterval=2, Language="nl", daysToCheck=13]
I tried with and without the daysToCheck but the same result
It seems like they have changed the token, again.
Next step is to add the token as a parameter so we can easily copy/paste it.
EDIT: token is added as a parameter and working for me.
Question: I would like to show the status in the item if there is no waste collection found.
Would that be OK?
Something like No token found
, empty token
, Nothing found
Yes, adding a message would be good idea
Compiled it for OH2.5 and OH3.1 and pushed it all to Github. Please check the README for the changes. I played around with the number of days and changing the token, it worked for me. But perhaps I missed some scenario’s.
Current token fetched from the website via developer tools is Crgja3EGWe8jdapyr4EEoMBgZACYYjRRcRpaMQrLDW9HJBvmgkfGQyYqLgeXPavAGvnJqkV87PBB2b8zx43q46sUgzqio4yRZbABhtKeagkVKypTEDjKfPgGycjLyJTtLHYpzwJgp4YmmCuJZN9ZmJY8CGEoFs8MKfdJpU9RjkEVfngmmk2LYD4QzFegLNKUbcCeAdEW
Let see how long it will last
Thanks, it works now.
Can you please explain how did you get the token?
Yes. Here you go:
- Open developer tools in your browser, shortkey is F12 in FireFox and Chrome
- Select the tab
Network
- Refresh the page
- Look for the file/page with the name
access-token
and select that line - Look for the request headers
- Look for the header
x-secret
- Copy that value
I found out that the x-secret is stored in the main.js file.
Line 5405.
var n=“Crgja3EGWe8jdapyr4EEoMBgZACYYjRRcRpaMQrLDW9HJBvmgkfGQyYqLgeXPavAGvn
JqkV87PBB2b8zx43q46sUgzqio4yRZbABhtKeagkVKypTEDjKfPgGycjLyJTtLHYpzwJgp4YmmCuJZN9ZmJY8CGEoFs8MKfdJpU9RjkEVfngmmk2LYD4QzFegLNKUbcCeAdEW”
This is the url to find the key.
https://www.recycleapp.be/static/js/main.8bdb8d89.chunk.js
Hi @BeanzBE,
Just found your API and works perfect! Many thanks!
Some suggestions i would make:
- Can you retract the nearest Recycle park, address, and opening hours?
- Why not returning the data into a JSON schema? it’s standardized, easier to get the needed info out of it,…
kind regards
Great to hear it helps others
Regarding your suggestions:
- I need to check the API
- It was built for personal use and I just want to show it as a text item. First feedback was to change format a bit. I will see if I can put it in a JSON and put it in another channel.
Hi Lennert,
Thanks to your binding i was able to handle the requests with some http requests and put everything into Rule DSL where I can handle the returned JSON data.
Many thanks
First at all, thank you for the effort!
I’ve just gave it a try. And for the moment, I’m just getting:
2022-02-03 19:20:41.255 [INFO ] [um.internal.RecycleappBelgiumHandler] - Start fetching next waste collection...
Will wait a few days if something new comes in?
Tomorrow is the pickup day over here.
I’ve also noticed that the token will expire right away? Not sure if this is important for the future?
"expiresAt": "2022-02-03T19:25:47.535Z",
"accessToken": "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpYXQiOjE2NDM5MTI4MDcsImV4cCI6MTY0MzkxNjQwNywiYXVkIjoicmVjeWNsZWFwcC5iZSJ9.OmzGVKFpYTM_i6svXvOEb7TroWu-SG5IbAzjUE4P_ao"
Maybe an addon? Today I’m using an own google Calendar where I copy this kind of data in. The end result is an image on my dashboard. I’ve created icons for most possible pickups. It’s done by a rule now, but maybe it can be added as an item state? Would be much easier.
The job runs every 12 hours by default, just to avoid being flagged as scraper. You can decrease it to 2 hours.
Mine is still showing data so it seems to be working. But if I remember correctly, the very first time nothing is shown. Then you have to wait 12 hours (or less).
I have never played around with images as an item state. It has been over 6 months since I touched this binding. No promises but if I’m getting bored I might play with this.
Just in case, do you mind sharing your icons/images?
For the moment, no updates from the binding.
I’ll try to play later on with postal code. When I enter it on the site, I’m getting a dropdown since several choices for our postal. Maybe it’s not enough for just a postal code?
Here is my latest set of waste icons.
For my garbage pickup calendar, I really only use the ‘rest’ and the ‘all’. In our street, one week is ‘Rest’, and the other week it’s ‘rest-pmd-paper’. The other icons are because I want to start to keep track on all our waste. So I’m building a scale to weight the waste , and inserts these values automaticlly.
Where I live, we have 3 cities for 1 postal code. So that should cover it.
You can always send me your address privately so I can test it. Perhaps there’s still a bug in my binding.
The token is still the same as last year, you can find it higher in this thread. The one you show is the access token the site will give the app to do the communication. We need to save the one marked as x-secret
Nice set of icons. Need to see if I can include that, no promises
A bit of patience, and the values roll in.
log/events.log.12:2022-02-04 17:14:38.581 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'afvalOphaling' changed from NULL to Nothing to show...
log/events.log.13:2022-02-05 01:16:43.281 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'afvalOphaling' changed from Nothing to show... to (2022-02-11)Restafval***PMD***Papier-karton
So your binding is working perfectly!
I’ve moved from my current situation, to your binding.
I’ve inserted the 2 main values into an seperate item. So they can be used in fe widgets. This is my end result (so far):
items:
String afvalOphaling "Volgend ophaling" <calendar> {channel="recycleappbelgium:Collection:home:NextCollection"}
String afvalOphalingImg
DateTime afvalOphalingDate "[%1$tA %1$td %1$tB]"
rule:
rule "Converteer afvalophaling"
Item afvalOphaling changed
val strAfvalVolgend = afvalOphaling.state.toString.split('\\(2').get(1)
val strAfvalDatum ="2" + strAfvalVolgend.split('\\)').get(0)
val afvalType =strAfvalVolgend.split('\\)').get(1)
afvalOphalingDate.postUpdate(strAfvalDatum)
if (afvalType == "Restafval") afvalOphalingImg.postUpdate("/static/afvalRE.png")
if (afvalType == "PMD") afvalOphalingImg.postUpdate("/static/afvalPM.png")
if (afvalType == "Papier-karton") afvalOphalingImg.postUpdate("/static/afvalPK.png")
if (afvalType == "Restafval***PMD***Papier-karton") afvalOphalingImg.postUpdate("/static/afvalAL.png")
Widget image card:
component: oh-image-card
item: afvalOphalingImg
title: = items.afvalOphalingDate.displayState
action: url
actionUrl: https://www.recycleapp.be/home
