Hi ,
I receive :Could not fetch token from website.
Is their a new token?
Could not find it with the developer tools on the website.
Patrick
Hi ,
Patrick
Hi Pat, I’m not aware that there is a new token. Mine is still working fine.
Token starts with Crgja3EGWe in my configuration. I can send you the token via PM, if you want.
Hi BeanzeBE,
I am also using the same token as in jelmer1 post from march 21 higher up.
The RecycleappBelgium Binding Thing is online, but the channel give me the same error:
Any idea why i cannot get the data.
Patrick
Looking into the code. Could you set debuglevel to debug?
Then some more info is saved. But I also see that I can improve logging on debug level.
Perhaps time to upgrade to OH3.3 and add some extra logging. MIght take some time though…
Hi BeanzBE,
I removed your binding and used the Waste Collection Belgium from the OH 3.3 rule template.
It works fine for the moment.
Patrick
Strange, also getting a token issue since a couple of weeks…
Worked for months. Just checked the token, and at first sight, it’s still the same.
