It is indeed a sensor that can recognize pipe flow patterns, so one would be enough to recognize (hopefully) the washingmachine from the toilet.
Ultramis and Kamstrup and some others make ultrasonic watermeters, but I am not sure if those can be used without cloud. The KAMSTRUP flowIQ2102 transmits data via a radiotransmitter and stores 480 days of data that can be read through an optical port, but as you are asking the question on OpenHab I guess you prefer something that has WiFi connectivity, but if you ‘just want a clamp on meter’ maybe the DCT1438K Ultrasonic clamp-on flow meter is something for you
Mind you that those meters generally are not cheap. The Fluid will eventually retail for 300 USD and that is not out of line with what I have seen on other ultrasonic meters. The DCT1438K is around 150 I think
Thanks for the information. It certainly would come with a price, as we would need two of those. One for the cold and one for the hot water. Interesting links anyhow, I went through them but now will bury the idea. Too pricey just for some grafs.
Hey it’s urgent please help me can i use the TDC GP-30 in DIY clamp on flow meter, does the power output of the transmitter and receiver is enough to penetrate PVC like material… I’m finding it from a whole months i really want a help please it’s urgent.
